Polk's newest design unveiled at CES
    nooshinjohn Posts: 26,182
    edited January 2014
    The tweeters have a certain RDO/ SL3k look to them, though the color is off just a bit... Silk Domes?
    Any other "retro-inspired" products in the 6FT tall, 200LB categories coming our way?
  • megasat16
    megasat16 Posts: 3,521
    edited January 2014
    Does Polk contracted Fisher Price to design these things? ;-)
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited January 2014
    I would definitely be interested in hearing what they sound like. To me personally, coming up with a complimentary subwoofer for nearfield monitor or occasional bookshelf use is a waste of Polk's time and energy. For music, I have never in my life heard a desktop system with a subwoofer sitting on the floor that sounded musical and well integrated, and I have heard a few speakers, both active and passive that sounded more than adequate on their own down into the bass range. The only spec that is somewhat disappointing to me is the bitrate on the USB connection. I don't think I've seen a USB 2.0 interface that wouldn't handle 24/96. I'm not really familiar with the idea of a DACless PWM amplififer, but Googled and found this to be a pretty compelling reason to give it a try: http://www.theabsolutesound.com/articles/nuforce-dda-100-integrated-amplifier-1/
    edited January 2014
    ^^^i guess you never got ears on the mini-Maggie's then. If ever I decide to do a desktop rig, they would top the short list. They are sublime.
    mhardy6647 Posts: 35,562
    edited January 2014
    ... that styling is considered "retro"?
    ruh-roh!
    I must be even older than I thought!
  • Face
    Face Posts: 14,340
    edited January 2014
    Do you like vocals coming from your sub?
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited January 2014
    On3s&Z3r0s wrote: »
    Surprisingly, the klipsch promedia 2.1 package sounds pretty damn good. Although I may be giving it undue praise as a result of having heard some really poor, one-thud computer subwoofer designs in the past.
    Anyhow, I don't doubt for a second that these Polk computer speakers will sound excellent. Black should probably be an option, as they don't stand out and blend with everything. Yeah, they need to be available in black.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
    edited January 2014
    Face wrote: »
    I have not heard them in my home, but I have heard a properly est up demo that did not have that problem.
    VR3 Posts: 29,762
    edited January 2014
    My desktop setup blends pretty well except I run the subwoofer pretty hot... because... well I can and I use it a lot for dubstep and techno.
    If I could get my ears on these monitors and they were available in a Ford Model T color I would maybe consider swapping my M Audio monitors for them.
  • D2Lo
    D2Lo Posts: 352
    edited March 2014
    some more images
    F1nut Posts: 52,406
    edited March 2014
    I see nothing.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    This is what I'm wondering too!
  • D2Lo
    D2Lo Posts: 352
    Yes, they are silk domes.
    I hear you on the second point.... I can't comment of course, but you are definitely being heard.
