2 PSW10's or 1-2 PSW505's
boston1450
boston1450 Posts: 7,758
edited January 2014 in Speakers
I have a small 15 - 12 or so living room using a PSW202 & its not cutting it for me. Wife isnt into thump but i am:) Should i use 1 subwoofer or two small ones? The PSW10's are cheap & the 505's arent too bad price wise. Will i benefit using 2 small ones if spaced apart by 12ft facing toward me toe'd in ?
Couch on rear wall facing front wall
Front wall has from left to right
Sub-L speaker--amp--r speaker- (sub)i could place a sub here
Im finding myself wanting more bass from sub than the little 202 is doing. Any ideas ? TIA
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
    edited January 2014
    More thump for movies or music ....or both ?
    The 505 should pressurize that small of a room pretty well. Buy one and see if you like it, 2 is overkill imho.
  • boston1450
    edited January 2014
    Movies mostly. The Monitors really dont need bass for music Imo. Your probably correct with 1. I may find the PSW10 doesnt cut it
    Randy-Maine
    by David WMG
    edited January 2014
    The 202 is probably a better sub than the 10, If you want more, then the psw10 shouldn't even be on your radar.....even 2 of them.
  • codyc1ark
    codyc1ark Posts: 2,539
    edited January 2014
    Yeah, the 10 is fairly puny. If your considering buying two 505s at a tune of what, 400ish? I would consider other companies that just plainly make better subs than Polk once your in that range. One GOOD sub will certainly perform better than two mediocre subs. At least in my opinion, but what's that worth??
    msg Posts: 10,472
    edited January 2014
    I also agree eel like it'd be better to start with a single larger sub, and go from there. my understanding is that "you can never have too much sub" (within reason), and that a larger one will simply work more efficiently, whereas the smaller one has to work harder.
    I just looked up the specs on both models, and it seems like the 505 can go lower, has way more power.
    Size is relatively similar, with the 505 weighing about 18lbs more.
    Also looks like it's got better controls.
    PSW10 - http://www.polkaudio.com/products/psw10
    PSW505 - http://www.polkaudio.com/products/psw505
    I'm kinda in the market for a sub too, so this is a timely post.
    If set on Polk subs, I'd go 505 of these two choices, but I also agree that possibly something from just sub people might be best all around. Personally, I'm considering HSU or SVS, my preference more for music.
  • boston1450
    edited January 2014
    Thanks. I need to spend some time researching different brands before pulling the trigger. There isnt much up in these area's to shop around & listening to them always helps
    Randy-Maine
    by David WMG
    msg Posts: 10,472
    edited January 2014
    man, I know exactly how you feel. I can't audition *any* of the Polk stuff around here. Closest store is Crutchfield, about 160 miles out. Everyone local just has B&W, Def Tech, Martin Logan, or just a handful of the midline TSx or TSi lines which are just sitting out on display at Best Buy, and never hooked up anywhere to listen to. I'm still curious about those, too, just the same. Sucks trying to go by reading reviews and stuff. helpful, but not the same as actually hearing them.
    about all I can say is that there's a significant difference in delivery from a 10" to a 12" sub in general, especially in similar lines.
  • snake1
    snake1 Posts: 567
    edited January 2014
    Just fyi, got my 505 ordered from newegg for $199. This sale price comes around fairly often if u watch it. Nothing but good to say about my 505, it rocks my 15x20 LR very well being corner loaded!
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • rooftop59
    rooftop59 Posts: 8,120
    edited January 2014
    Yes I would definitely go with something like this this http://www.hsuresearch.com/products/stf-2.html if you are considering spending 4 bills. Remember that all you get from two subs is about a 3 db increase and possibly a flater response curse. Check out these reviews, both by Ed Mullen of SVS for info:
    http://www.hometheaterforum.com/topic/188634-hsu-research-stf-2-subwoofer-test-review/
    http://www.hometheaterhifi.com/volume_12_2/polk-psw-505-subwoofer-4-2005.html
    Game Room 5.1.4:
    Bedroom 2.1
    edited January 2014
    If you want to stay in the $200 dollar or less range. It's hard to beat the PSW505. I use a sub that has specs close to that that I bought for the ridiculous price of, you guessed it, $200 including shipping (MSRP $499--product was discontinued).
    12" woofer, 300 watt RMS digital amp/600 watts peak (so a little more than the 505--but not really significantly), weighing in at 46-47 lbs. with a "supposed" 25hz bottom at +/- 3 db...so maybe a tad lower than the 28hz of the PSW505. But practically speaking very very similar.
    I run this sub in an 11.5' x 17' listening space (there is another 8' of length behind the sofa, so 11.5' x 25') but there's a game table back there!
    Let me tell you, this might not be the greatest sub you can get, sure you can spend hundreds more or thousands, but it DOES rattle the windows, shake the floors and disturbs my wife's office on the floor above the game room. For movies you can't go wrong, it is, though a tad slow, for some music but I don't use it for that!
    So yes, the PSW505 will do the job in your room and do it on a "budget". If you have the money go ahead and step it up, you certainly won't regret it. But if this is mostly for film. The Polk will give that small room all the LFEs it can handle for now and leave some money in YOUR pocket!
    cnh
  • boston1450
    edited January 2014
    ^^^ thanks everyone.. The pisser is i had a wonderful Velodyne & i never thought id go HT. I may check NewEgg 199 is 50 less than i saw on the bay
    Randy-Maine
    by David WMG
  • halo71
    halo71 Posts: 4,638
    edited January 2014
    Distributed bass! Get two of whatever it is you buy.
    --Gary--
    edited January 2014
    boston1450 wrote: »
    You may have to wait for when newegg puts those on sale. It happens fairly often!
    cnh
  • larry777
    larry777 Posts: 480
    edited January 2014
    The 505 is a VG sub for movies at its price point ( I have one waiting to go in a second H/T setup down stairs ). It will fit your room nicely as it isn't a large sub. One sub will give a neater appearance to your room, especially when it is put in the corner position.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • boston1450
    edited January 2014
    Newegg had the 505 for 149.00 but expired. That would be a great buy
    Randy-Maine
    by David WMG
  • PolishDude
    PolishDude Posts: 58
    edited January 2014
