RT55 drop out issues
mtjo62
mtjo62 Posts: 2
edited January 2014 in Troubleshooting
I recently obtained a pair of RT55 speakers. We tested them with a Peavey M-2600 power amp which supplies 75W into 8 ohms. We then connected them to an Optimus AV amp which supplies similar wattage. When you set the volume at 12 o'clock or so on either amp, the power drops out. I am assuming this is the amps internal protection circuit kicking in. Both amps are normally used to run a pair of 8 ohm PA speakers and we haven't had this issue before and we have run them well past 12 o'clock. Any ideas on why this is happening?
Post edited by mtjo62 on
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I have had 3 set, currently still using 2 sets of them. I can play mine very loud with no problems. They handle everything my Onkyo TX-NR809 gives them. All of mine have given completely trouble free use.
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
  • Gempler
    Gempler Posts: 308
    edited January 2014
    Despite what sounds like some thorough investigating on your part it really seems like the symptoms point to an amp issue. I don't know if there is any protection circuitry in the crossover of the RT55 that would cut off the speakers but if you are confident that it isn't your amp then you might want to look at the crossovers. Here's a nice youtube video that shows how to get the crossovers out:
    http://www.youtube.com/watch?v=QxVf0n5hydE
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I am not familiar with the circuitry on them, as far as I know its only a cross over. If there is a circuit protection feature in there they don't show on all 3 sets I have owned. Hopefully its something you can get figurered out, they are great speakers.
  • mtjo62
    mtjo62 Posts: 2
    edited January 2014
    I really like these speakers and I am determined to get them working without these issues. I had already inspected the crossovers and there appears to be no protection device. Considering that both speakers/channels drop out simultaneously, I am not suspecting component failure in the crossovers and both speakers appear to be all original parts. If I have to make an assumption here, they may do better with a higher powered amp for more clean headroom. I read elsewhere that the RT55s work better with 14 or 16 gauge cables. We have been testing using shielded speaker cables and I suspect they have an 18 gauge conductor.
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    If you get it figured out you will enjoy them. Good luck with them.
  • Easy Runnin
    Easy Runnin Posts: 501
    edited January 2014
    Since you have 4 binding post per speaker, try them with the jumper, without the jumper on the top set and without the jumper on the bottom set u see if the same thing happens.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
    tonyb Posts: 33,072
    edited January 2014
    Pa speakers are built for louder SPL's, home speakers are not in that league. The 12 o'clock position on the volume dial is dangerous territory for home speakers. Back off that volume dial dude, they are not going to be as loud as PA speakers.
