another bi-amp/bi-wiring question - please help
smallknuckles
smallknuckles Posts: 2
i just bought the Onkyo HT-R2295 and 2 Polk Audio Monitor70 Series II. it doesnt say anything in the guide about bi-amp option.
but i will have the open space for the front high. will this work?
  • kcoc321
    kcoc321 Posts: 1,788
    edited January 2014
    Does't do anything bi-amping with a receiver.
  • smallknuckles
    edited January 2014
    kcoc321 wrote: »
    Ok maybe I am wording it wrong. Is there any advantages to hooking up the surround/front high to my speakers ? And the front channels?
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2014
    None whatsoever. Please do a search in the forum, this have been covered numerous times.
    Main Surround -
    F1nut Posts: 52,371
    edited January 2014
    There is a disadvantage. The more channels you use on that AVR, the less wpc it can provide. Honestly, you shouldn't expect much from a $499.00 list, $150.00 street price AVR.
    F1nut Posts: 52,371
    edited January 2014
    Found some specs, 130 W/Ch (6 Ohms, 1 kHz, 1% THD, 1 Channel Driven)
    That's at 6 ohms, your speakers are 8 ohms, so the actual wpc will be even less AND that's with only one channel driven AND 1% THD too boot! They don't even list the weight for this thing.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited January 2014
    Hi welcome, enjoy your receiver and speakers. Later on you will get something else.
    Hooking it up normally will provide a decent listening level and there is nothing to
    gain as you would still be borrowing from your single power supply on board. Hopefully
    you have only a moderate size room and don't plan on getting crazy with the loudness.
  • fun_dador
    fun_dador Posts: 28
    edited January 2014
    I agree with polkieman....
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    edited January 2014
    PolkieMan wrote: »
    This ^^^
    Congratulations!! The M70's are a potentially great speaker! Before upgrading your M70's, consider upgrading the power, the 70's love the power.
