Left channel blew from static discharge
Jhayman
Jhayman Posts: 1,548
edited January 2014 in Troubleshooting
My beloved McCormack DNA-250 lost it's left channel last night as I touched the pre amp to turn it down a big static shock followed by a very loud hum result no left channel.
Well it's there but extremely low might as well not be there.
I checked preamp channels to verify and still no sound so I swap left speaker to right channel and it works..
Any thoughts on what could have blown here's a few pics..
Will pits pics a bit later as I have to make the file size smaller to fit..
But it looks fine to me inside the fuse seems fine but oh knows..
Post edited by Jhayman on
  • Glen B
    Glen B Posts: 269
    edited January 2014
    You mention some swapping of speakers, but I'm not clear what you did. You need to check each amp channel individually with a working signal source to rule out a blown channel. If both amp channels are fine, you know the problem is in the preamp.
  • Jhayman
    edited January 2014
    I disconnected the right channel IC which works fine, then I switched the left channel IC from amp to the right channel on preamp and nothing..
    heiney9 Posts: 25,483
    edited January 2014
    Static discharge can be death for some gear. Also any sort of in rush/pop from turning source gear on in the wrong order.
  • Hermitism
    Hermitism Posts: 4,329
    edited January 2014
    I've been getting a pop in my tweeters sometimes when I will hit the menu button on the remote for my Blu-ray player. I also have an upscaling DVD player hooked up and it does the same thing. The reason I have two hooked up is I've been watching a TV show on DVD, and it's just easier than having to remove the disc every time I want to watch a movie. But it happens on both the DVD and Blu-ray players. It's not as loud as calibrating my AVR, but it's not subtle. I haven't noticed it when listening to music CDs and using the remote to skip through songs. Does my system have gremlins?
  • Jhayman
    edited January 2014
    Just called the shop I picked it up from he said probably a fuse I checked inside both fuses are fine I even swapped fuses to see just in case it was blown bug did not look it..
    So I'm bring it in tomorrow I'm on a weeks holidays this week now this really sucks oh well I guess I'll use my back up system Yamaha CR-2020.
    F1nut Posts: 51,880
    edited January 2014
    IMO, the problem is going to be in the pre amp. Did you check the fuses in the amp or the pre amp? If it was the pre amp that you checked the fuses in and they are ok, then you will need to take to the shop.
    BTW, a fuse can blow and still look good, but since you swapped them it would seem they are ok.
  • Jhayman
    edited January 2014
    Jesse I checked the amp fuses and swapped them to see if it was just a fuse..
    It's the amp nothing out of the left channel, I checked left and right channels on the preamp and switched ICs from left to right the right channel on amp will work on both left and right channels on preamp, but if I try the left channel on amp and swim it from left to right only right channel has sound..
    I have pics but they are 1.5mb in size to big to post on here, not sure how to shrink them down to post here 512k is maximum size for Polk..
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2014
    Good luck. It sucks bigtime to have a piece of broken gear. Hope you get it fixed fast.
    F1nut Posts: 51,880
    edited January 2014
    Jhayman wrote: »
    Interesting that the charge didn't damage the pre amp and went thru to the amp. Anyway, it could have taken out anything from resistors to output devices in the amp. Best have your tech look at it.
  • Jhayman
    edited January 2014
    Yes my initial thought was the preamp because that's what I touched first.
    I was in the process of turning it down to change the album and when I touched the volume button I saw a spark and then a very very loud hum and I immediately pressed the power button to turn it off, maybe tests what saved the preamp and allowed the signal to get to the amp..
    Either way I'm pissed as I have a little play money to upgrade something but now I hope it's covered under a warranty of sorts, at least I would have thought a fuse inside would have blown to save it..
  • Irrenhaus
    Irrenhaus Posts: 1,105
    edited January 2014
    Jhayman wrote: »
    Sorry to hear about the Amp no help there from me. But for the pictures if you are using windows, open the picture using Paint then select resize and go for 50 on the Horizontal and Vertical. You may have to do it one or two of times until you get below 512K.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Jhayman
    edited January 2014
    I took them on my iPad and while I love my iPad I really really hate anything else Apple because you gave to use iTunes and iTunes is the biggest piece of garbage on the planet..period..
    Irrenhaus wrote: »
    Cheers
  • Irrenhaus
    edited January 2014
    Jhayman wrote: »
    Ohh not a Apple fan here. But can you email the pictures to yourself that may work....
    Here
    http://lifehacker.com/5822109/how-to-email-photos-from-your-iphone-ipod-touch-and-ipad
    Cheers
  • Jhayman
    edited January 2014
    I'm Happy once again..
    Got my McCormack back last night and it did not cost me a penny.
    Excellent customer service from Harley at Audio Empire
    Sounds Great and I also picked up a Ortofon 2M Black and what a difference in detail, love the new cart..
  • Jhayman
    edited January 2014
    I'm not sure exactly when I asked he said it was something to do with the input stage..
