SDA SRS2's in the house...
nooshinjohn
Just scored...
http://losangeles.craigslist.org/sfv/pho/4266022742.html
These will become the side/rear surrounds of my HT build. I plan on building the SRS2's right into the walls, and using Polk RM7500's as rear height and front height speakers.
Post edited by nooshinjohn on
very nice score, nice price, too . . .AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I assume you dont connect the SDA cord when using them in this fashion?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Im comin over with a bottle of Grey Goose and some movies!"Everything I ever did in my life worthwhile I caught hell for"
bobsauto49 wrote: »Im comin over with a bottle of Grey Goose and some movies!
You are welcome any time. It should be quite entertaining to have this kind of firepower in the HT room. I see no need for subs of any kind with 4 15" passives in the room. Should also prove to be quite musical as well for concert videos.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Do I have to share the Grey Goose? :cheesygrin:"Everything I ever did in my life worthwhile I caught hell for"
bobsauto49 wrote: »Do I have to share the Grey Goose? :cheesygrin:
Only if you want to be allowed to sit in the sweet spot.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Sorry John, I don't see that working out very well.Political Correctness'.........defined
President of Club Polk -
It may not, but for the price, it's worth a shot. There are no other speakers I could get for the price that would be better.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Congrat's but I gotta tell ya', that's a bad idea John.
I don't plan to run them with the SDA cable, but rather to wire them up as regular stereo speakers. I know I have been here a while but still need to get my learn on. Why would this not be a good idea?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I wasn't talking about the SDA cable, although you are on the right track without it being in use. I was talking about the same thing F1 mentioned. That being the placement of the speakers built within a wall. No matter how you slice it, the end result will not turn out good.
So if I stand them 6 inches off the wall and not build them in, it will work? Or an I better off moving these off to a friend?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
It would definitely sound better if your room is big enough John. These type of speakers are not engineered to be built in wall and need room to breathe. The only possible benefit to having them in-wall would be the equivalent of an infinite baffle, if you will, but the disadvantages would greatly outweigh any benefit of that type of baffle.
The room is 20 feet on the long wall by 16 feet on the short wall. The 1.2TL's are set to be 42 inches off the side walls.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Congrats John, those look like a really clean pair of early model SDA-SRS2 with the blade/blade IC. Possibly 1986? I'm running a pair SDA-SRS2's pin/blade 1987 speaks as my mains in a 20' x 22' x 9' room. Will be interesting to hear how your setup sounds, what size of room are you working with there?
Just hook em up near where they will be and hear for yourself what they sound like.
We expect a full report!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Perfectly. Six inches off the back wall is in the ideal range.
If you get SDA's too close to a back wall they become a boomy mess. The same would happen if put into a wall.Political Correctness'.........defined
My 2.3tl's are quite a bit off the walls.I found the more space around them the better.
Now the only boomy mess in the room is me.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Good score John, a lot of SRS 2's coming out of the woodwork lately!
Enjoy John nice find.Home Theater
Great find John. Enjoy!
Yea whatever you decide to do with them they are very nice and the price was well quite a stealPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
nice score and posts some pics after you guys finish the goose
Congrats. When I first set up my Home Theater with SDAs, I had my 2As in front, and my CRS+s in the rear, on stands so the drivers were above ear height when seated. The CRS+s were setup with the interconnect, and I used the 5.1 setting. It was very enveloping to say the least. The main problem was you had to be in the sweet spot for both pairs. I've since moved to a custom 7.1, but the old setup was still very effective. Try them as rear/surrounds with the cable in 5.1, and see what they sound like.Home Theater/2 Channel:
dhsspeakerservice.com/ -
SRS 2s are very nice speakers, and you did get them for a good price. Congrats on another pair of great speakers and what sounds like a great home theater.
1.2TL's as fronts and SRS 2's as surrounds?
I don't think you can get any bigger surrounds than that.
No pictures?HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
I have been trying to make contact for several days now to go get them, but he is not returning my calls and now the ad is down... guess it turned into a highest bidder scenario:frown:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
That would be a very crappy feeling.
