My Custom Speaker Stands
marine5068
marine5068 Posts: 4
edited July 2014 in Custom Fabrication
Custom Fabricated Speaker Stands
Materials:
a) 1/4" thick aluminum plate for 12"x12" bottom plates and for the 6.5"x11" top plates.
b) 2"x4" extruded aluminum angles to make a rectangular vertical tube for the risers.
c) 1/4" thick, peel and stick high density rubber for the isolation pads on top of the speaker base plates and under the floor base plates.
Post edited by marine5068 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2014
    Kool nice work, where you going to leave them as they are or paint them?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    Toolfan66 Posts: 16,837
    edited January 2014
    Fill the tubes up with sand or lead shot..
  • GlennDog
    GlennDog Posts: 3,084
    edited January 2014
    nice work . . .
    Welcome to Club Polk!
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • lanchile
    lanchile Posts: 560
    edited January 2014
    Very nice stands, paint them with flat black paint (spray). I have to agree with the sand filling thing! Metal speaker stands can resonate. I am in the process of building my "wood" speakers stands with material from Home depot (no more than $30)
    Make it simple...Make it better!
  • hewlew1
    hewlew1 Posts: 154
    edited January 2014
    Very nice . I built a pair of stands from old planking which I removed from a house that I am redoing. Cost me only about three bucks for 3 cans of black spray paint.
  • zane77
    zane77 Posts: 1,696
    edited January 2014
    Very nice welding job, I agree fill the risers with sand or shot.
    Two Channel
  • ken brydson
    ken brydson Posts: 8,640
    edited January 2014
    hewlew1 wrote: »
    WHERE DID YOU FIND THE PAINT???? :cheesygrin:
  • jacks2start
    jacks2start Posts: 98
    edited January 2014
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    When will you be taking orders? I have a set of RT55's that would be at home on those!
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
  • xjghost
    xjghost Posts: 1,080
    edited January 2014
    Nicely done. I would love to learn aluminum welding.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • madmax
    madmax Posts: 12,434
    edited January 2014
    My initial thought too!
    Vinyl, the final frontier...
  • 20hz
    20hz Posts: 636
    edited May 2014
    I like the stands ! did the heat bend the plates at all ?
    Did you angle the top plate ?
    I wouldnt paint them maybe rattle can some satin clear coat on them ..
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    I like the idea about filing with lead or sand, seems like the alum might ring some
    I filed mine with grout
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • shawn474
    shawn474 Posts: 3,047
    edited May 2014
    I would consider bedlining them; gives them a textured finish with durability and grip.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • lilylily608
    lilylily608 Posts: 15
    edited May 2014
    thanks for your sharing!
  • Phatattack
    Phatattack Posts: 30
    edited May 2014
    Sick stands! Black anodized and i want a set :)
  • Moose68Bash
    Moose68Bash Posts: 3,842
    edited May 2014
    Great stands! I agree with the black anodized suggestion -- lloks great on aluminum.
  • Sea
    Sea Posts: 317
    edited June 2014
    Very Nice.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
    edited June 2014
    Nice industrial look and probably indestructible.
    Question to all the folks above. Now that the metal is "welded" just how would you fill it with sand or shot? Use a "transporter to beam the material inside?
    cnh
  • gce
    gce Posts: 2,158
    edited June 2014
    cnh wrote: »
    cnh
    Drill a hole in the top! :rolleyes:
    Anaheim Hills CA,
  • lilylily608
    edited July 2014
  • deronb1
    deronb1 Posts: 5,021
    edited July 2014
    Long strip of dynamat along the back might help with the ringing if you dont want to fill
  • kdblove_99
    kdblove_99 Posts: 107
    edited July 2014
    I would also paint them
  • strokin
    strokin Posts: 63
    gce wrote: »
    cnh wrote: »
    cnh
    I was thinking the same thing.
  • ThomasD
    ThomasD Posts: 260
    Just found this thread and had to resurrect it . I'm stoked 'cause this is exactly what I've been contemplating to use to make stands for my 7's. I can't weld to save my life but I have a friend who is an incredible aluminum welder, it's his profession. Just wanted to check to see if there was anymore information / conclusions about mass filling or finishing the aluminum.
    marine5068 wrote: »
    Materials:
    Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
    F1nut Posts: 49,711
    You definitely do not want rubber pads between the stand and floor. Spikes are the name of the game there.
