Odyssey candela
vmaxer
vmaxer Posts: 5,120
edited January 2014 in Troubleshooting
Hi,
I bought a Odyssey Candela here back in April and just hooked it up a few days ago. It works great except the remote, absolutely no response at all.
Any ideas?? The batteries are good.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
    VR3 Posts: 29,444
    edited January 2014
    I would call Klaus
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2014
    VR3 wrote: »
    I would call Klaus
    I will,but thought I would ask here to see if anyone had any ideas.
    Thanks a lot!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,444
    edited January 2014
    Hmmm, it is a simple set up -
    I will say the remote is garbage unless you have the fancy $200 version, chances are the remote is crap.
    The Harmony universal has a selection for the Candela to program if you have one.
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2014
    The one I have is plastic, i sure hope it didn't cost $200.00. I bought the unit off the forum here used. I will say I like it a lot, my first tube pre.
    I do have a small Dared that I used in my office. I like it also,hard to believe the sound from such a small unit.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2014
    I forgot to mention, butI do have a Harmony one I bought some time ago that I don't use. Where do I find the program for it, on the web site?? I never really got it set up before.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,444
    edited January 2014
    It has been years but once you plug it into the computer, load the software, there should be a setting
  • drumminman
    drumminman Posts: 3,396
    edited January 2014
    Congrats on your Candela. I've had one for the last 3-4 years and I love it. I bought it I also got the remote from Odyssey for the sole purpose of volume control. It performs a lot of other functions as well, just not for the linestage. I believe the remote was originally designed for the Symphonic Line CD player.
    As Trey said, call Klaus. He'll make it right.
    I've found that the Candela is very responsive to tube rolling. What tubes are you using now?
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2014
    drumminman wrote: »
    I will call his a soon as I get a chance, work is crazy busy now so I don't have much time at all during the day.
    I haven't opened it up to see what tubes are in it yet. What are some good ones?? I have it feeding a GFA 555 going to a stock set of 2B studios I just got from the original owner. The system is dead quiet, I can pause a CD and crank the volume wide open and dead quiet.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • kcoc321
    kcoc321 Posts: 1,788
    edited January 2014
    From their web site it takes (2) ECC82/12AU7 tubes
    http://www.odysseyaudio.com/products-candela.html
    You'll have to wait for the tube experts to weigh in as to which tubes are the best to use :)
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2014
    kcoc321 wrote: »
    Yes, I had looked and saw that, just don't know which tube to go for. Hopefully someone will chime in and let me know which ones to go for.
    Thanks for the tip though.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • drumminman
    edited January 2014
    Mine came stock with JJ Tesla 12AU7's, which sounded good. I then rolled in some RCA clear tops, which are not all that expensive. I paid $40 for a matched pair. The improvement was dramatic. Then I rolled in some Amperex 7316's late 50's vintage. Those brought the same degree of improvement over the clear tops that the clear tops did over the JJ's.
    I've also read that Candela owners like tubes in the 5814 family, which I'm getting ready to try as the Amperex's have gotten noisy. Brent Jessee is a respected tube dealer; not the cheapest, but I've had good luck dealing with him. Here's his website: http://www.audiotubes.com/
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2014
    I pulled the tubes out of mine, no info at all other than the 12AU7???
    I will check around and see what I can find. Thanks a lot for the info!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
