Sub-woofer or center speaker?
tkavan
tkavan Posts: 4
I have two Polk T300s, eight feet apart and about 14 feet from the listening area.
They are used primarily for music, mostly classical, and not for TV.
Which would be a better third speaker: a sub-woofer or a center speaker?
Thanks for any advice.
Tom K.
Post edited by tkavan on
  • ken brydson
    ken brydson Posts: 9,029
    edited December 2013
    Welcome to CP Tom. I would go with a sub.
    treitz3 Posts: 20,134
    Hello and welcome to Club Polk Tom. I will second the vote in your case for a sub. Properly integrated, you will find that much of the music you listen too is missing without one. Not a night and day difference but enough to thoroughly enjoy the music all over again.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Welcome to the Club. Sub it is.
  • tkavan
    tkavan Posts: 4
    A follow-up question: Does the cable to the sub have to be the same length as the cables to the right and left speakers?
    No.
  • tkavan
    tkavan Posts: 4
    Thanks, everyone, for the speedy responses.
    I've just bought a PSW108.
    Tom K.
  • classic carl
    classic carl Posts: 662
    edited January 2014
    What are you using for an amp? If you aren't connecting the TV audio through your speakers, I'm assuming you are using a 2 channel amp. Therefore, a center channel speaker is useless.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • tkavan
    tkavan Posts: 4
    edited January 2014
    I'm using a Pioneer av receiver, which has outputs for both a sub and a center speaker.
    I'll think about a center speaker later, but the system is just for music and most of the comments I've read about center speakers seem to indicate that its main purpose is to focus the dialogue to where the TV is.
  • classic carl
    edited January 2014
    tkavan wrote: »
    You are correct. When I use my HT to watch/listen to a concert DVD. I bypass the center and surround speakers and just use the mains and 2 subs listed below in my signature. I have a separate 2.1 system for CD and vinyl music listening.
    Main System 2.2:
    Home Theater 5.2:
