Gold Lion KT-77 vs. SED Winged C EL-34
stretchl
These will be for my Yaqin MC-10t.
With the stock EL-34's that came in the unit, I was left wanting a bit more bass out of my LSi-M705's.
Any thoughts on which might make me the happiest camper?
Thanks.
http://www.upscaleaudio.com/svetlana-sed-winged-c-el34/
http://www.upscaleaudio.com/products/Gold-Lion-KT77.html
Thanks.
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
SED =C= are hard to beat overall. I can't say as I haven't heard the GL KT77."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Thanks, H9. Looking at several of your previous posts has me leaning toward the Winged C's, but I just wonder about that bass…“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
I didn't notice any difference in bass response between the Winged C's and the Shuguang EL-34B's in my Yaqin MC-30L.SDA SRS 2.3TL's
SDA 2B TL's -
Thanks, Michael!“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Stretch................I had that same amp and I had some Shuguang Black Treasure 6CA7 (power) tubes in there and the sound was awesome. I highly recommend them. The bass is more profound in the 6CA7 tubes. Yaqin also had some 6CA7 tubes that they supplied as an upgraded tube which sounded pretty good as wellMain Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
take a look at the eh 6ca7's.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Thanks and thanks!“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Excellent tube!Political Correctness'.........defined
President of Club Polk -
Did you sense that you lost any midrange warmth at all?“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
yes, i just don't know anything about the seller.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Thats the thing for me. I know so little about tubes that I really feel I should stick with marquee vendors. Upscale Audio and Grant Fidelity, for instance. Any others to add to the list?“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Also how long do tubes normally last?2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Well, Grant no longer sells the Treasure 6ca7's, but Rachel recommends these:
http://psvanetube.com/wordpress/store/products/6ca7-t-quad/
That phrase, "Sonically the T-series is considered modern refined with more top end extension," scares me a bit. Makes me think of pop music compression and solid state amplification. Those sorts of things aggravate my tinnitus in a way that the "NOS laid back tube sound" seems not to.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Thanks for the rec, George. I'll check them out.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
george daniel wrote: »Hell no.
^^^^^^What He Said^^^^^^Main Rig:
Second Rig:
Ok, sold. I think I'm going to go with the black treasures
- Isaac Asimov
Hi-Fi
Visuals
You wont regret it Strech..........allow for some burn -in time before real evaluation, but they're good out the boxMain Rig:
Second Rig:
Yep, like 300 hours and they will change character a lot over that time span from horrible to total sonic bliss and everything in between.Political Correctness'.........defined
OK, question about burn in, then:
Would you advise running the unit for extended periods, say overnights with the volume set very low, to help rack up hours?
Or just play them like I normally would?
Thanks.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Yeah, that's not an easy one to answer. I have never been comfortable leaving a tube amp on unattended for an extended period of time, such as overnight while being asleep. On the other hand it would certainly speed up the burn in time, your call.Political Correctness'.........defined
Ya, makes me a little queazy, too.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
I've never left my tube amps playing overnite while asleep. I'd do whatever Jesse does. My thinking is, I'd rather wait a little longer than to have something bad happenMain Rig:
Second Rig:
