Trouble with movie voice tracks
muncybob
muncybob Posts: 3,267
edited January 2014 in Troubleshooting
Using an Oppo 93 thru an older Yamaha receiver. Everything hooked up using rca cables in multi channel. Recently I have noticed that from time to time the vocals sound as though they are in a church. Some sort of mild reverb or echo is the best I can describe it. It will only last for a short time but seems to be happening more frequently. Any ideas?
Yep, my name really is Bob.
Post edited by muncybob on
  • erniejade
    erniejade Posts: 6,321
    edited January 2014
    This might sound strange but, for me, if by accident i leave the tv volume up, i have that same issue. Is the tv volume off?
  • muncybob
    edited January 2014
    I know what you are talking about and it sort of does sound like that but it comes and goes. The TV audio is muted.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited January 2014
    This might sound wacky but 1 thing about my Yamaha I don't like are the settings for music. Just possibly you hit the music button and went into a different sound scenario like Vienna Hall, ,Roxy Theater,Hall in Munich, Chamber all music audio sources that what it does as far as I'm concerned is add echo and delay and is a waste of time. Also the same thing applies for movie sources w/ adventure, sci-fi,spectacle and standard doing basically the same thing.I would check your setting on your remote and go back to just 5.1 or on the rx-v665 7.1.
  • muncybob
    edited January 2014
    Well ernie, you sort of got it. My TV was muted...or so I thought. Apparently my Harmony remote would sometimes leave TV muted and other times when I used the single button to watch a movie it would turn on the TV speakers. I guess I need to reprogram the remote. I'm glad it is something as simple as this, I usually don't get this lucky!
