What glue to use
polklifer
polklifer Posts: 40
edited December 2013 in Vintage Speakers
Hi all, am wanting to re-glue the magnets on my SRS 3.1's, and was wondering what the glue of choice here is. Is Gorilla glue an acceptable solution?
Thank you
Post edited by polklifer on
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Although I've not tried it, some have used JB Weld. It's a little more money, but for metal to metal bonding, it's good stuff.
  • westmassguy
    westmassguy Posts: 6,850
    Gorilla urethane glue should be used for wood products only. Some use JB Weld or other forms of Epoxy. I use Loctite Power Grab Clear Acrylic Adhesive. Put a bead on the top and bottom of the magnet assembly, smooth it out with your finger tip, wipe off any excess, and let it dry for a couple hours. Cleanup with soap and water. Very professional looking when completed.
    Mike, The front and back plates are metal, however the magnets are ceramic.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have not used it in this application, but jb weld does work great also look at pc7. After curing this stuff is stuck forever
    Garage | Polk Monitor 5B's
  • polklifer
    polklifer Posts: 40
    Thanks all, I am going to use JB weld, I will post pics of the process if anyone is interested
  • Schurkey
    Schurkey Posts: 2,122
    Are the magnets STILL ATTACHED to the rest of the speaker?
    If not, epoxy is not the proper product.
  • drumminman
    drumminman Posts: 3,396
    Schurkey wrote: »
    Not sure what you mean, but I've used JB Weld and it works great. I've used both the stuff that comes in two tubes that you mix, and the putty that you knead together to mix the two parts. The latter is very strong, but perhaps not quite as strong as the former.
  • Mike Reeter
    I also use the Loctite Power Grab for just about everything, reattaching side panels on SDA cabs. resealing interior seams in the cabs. I guess I need to apply some to the driver magnets also.
  • Schurkey
    Schurkey wrote: »
    drumminman wrote: »
    If the magnet and pole piece are still attached to a working speaker, epoxy may be a suitable product to keep the magnet and pole-piece in place.
    If the magnet or the pole piece has already separated (non-functioning speaker driver) there are WAY better adhesives to put the thing back together with.
  • westmassguy
    It works great, and the end result is very neat and professional looking. JB Weld and Epoxies can get messy.
    F1nut Posts: 51,925
    I know what you are saying, so don't take this wrong. IMO, Gorilla glue should never be used for any reason.
  • westmassguy
    Oh I agree Jesse, it's unpredictable and makes a mess.
  • mikemokr
    mikemokr Posts: 150
    polklifer wrote: »
    Yes I'm interested in mods-by-numbers. If I ever start doing this stuff myself, Lord knows I'll need all the help I can get.
    Main HT (family room): Polk Monitor 7 (1987-original owner) (L/R) / CSi40 (C) / RTi38 (SL/SR) / SVS 20-39PC (sub), Outlaw 975 pre/pro / Outlaw 7075 amp, Oppo BDP-93 Blu-ray, LG 42LM5800 teevee
    2ch (family room): CRS+ (1987), Outlaw 1050 AVR, Denon DCM-420 CD
    Kitchen satellite 2ch: Polk M3II, Topping TP-20 Tripath amp fed from 975 rec line out
    Home office: Model 5 (1978-Danish Peerless), Lepai 2020A+ Tripath amp fed by laptop dock
    Awaiting assignment: PSW202 (NIB) to be wired inline in home office rig; Monitor 5JR (1988), Model 4 (1983-US Peerless)
  • oldmodman
    oldmodman Posts: 740
    A tip on JB Weld.
    I mix up a speakers worth at a time and load it into a medical syringe. Then heat it in hot water (don't let any water get into the tip where the glue will come out). It comes out fluid enough to make a very smooth and nice bead. But only do a little at a time. The heating causes a quicker cure.
  • drumminman
    I mix up enough to do one driver at a time and apply it with a small wood shim. I wipe off any excess with a clean paper towel. Probably not as neat as the syringe method, but you're not going to see it and that driver is not going to experience magnet shift short of taking an RPG direct hit :lol:
  • bigaltx24
    bigaltx24 Posts: 141
    If you want the magnets to stay put forever, use epoxy. I've seen acrylics fail on metals before.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • westmassguy
    bigaltx24 wrote: »
    Not all acrylics are created equal. I chose Loctite Power Grab because it bonds to ceramic, which the magnets are made from, and non-corrosive metals. The front and back plates of the magnet assembly are made of cadmium plated steel, which should never corrode in a sealed cabinet. It's also silicone free, unlike most other acrylics. If applied correctly, when you smooth it out with your finger tip, the product is pushed into the small gap between the plates and the magnet. It's difficult to accomplish that with epoxy.
  • drumminman
    I had no issues - don a pair of disposable rubber gloves and it's easy to work it into the gaps. I like the JB Weld because it provides a stronger bond, though the Loctite is probably strong enough.
    I do like the Power Grab for other applications, such as resealing the insides of speaker cabs. Has almost no VOC's so outgassing is not a problem for delicate parts like MW's and tweeters.
  • TennMan
    TennMan Posts: 1,266
    Power grab should be great on wood inside the cabinet. When I built my house the trim carpenters used it on the ends of the pieces of crown mounding where they joined together. Nine years latter there still are no cracks in the paint in the corners.
  • westmassguy
    drumminman wrote: »
    I've shipped several pairs of speakers across the country, and the Loctite held perfectly. In one case, one of the magnets shifted when the speakers were sent to me. A replacement driver was installed, and the other 3 received the Loctite.
  • Mystery
    Mystery Posts: 2,546
    Use Loctite red.
    Gorilla glue is only for fixing gorillas. :lol:
  • TennMan
    Mystery wrote: »
    Use Loctite red.
    If by Loctite Red you are referring to the Loctite thread locker I think it would be a bad choice for sealing magnets or cabinets. It is intended to only work in the absance of air and would not harden properly smeared on the outside of the magnet.
  • Mystery
    TennMan wrote: »
    Between plate and magnet. I mean when magnet is off the plate completely.
    For reinforcement from outside, JB weld or other epoxy is good.
  • TennMan
    Mystery wrote: »
    OK, that would probably work. Sorry I misunderstood what you meant.
  • Mystery
    TennMan wrote: »
    My bad is I didn't read all the posts so went by re-glue magnets on the 1st post and ****-u-me that magnets are off.
    If magnets are still attached and it's just to avoid future shift magnets, epoxy is the way to go.
