HD speaker cables
  • dcarlson
    dcarlson Posts: 1,740
    edited July 2004
    Originally posted by Willow
    all this aside are my clear coat 10awg hd speakercables junk ?? and be honest !!
    Please and thanks
    Junk, probably not. Are there better cables out there... certainly. But they do come at a price.
    Personally, I wouldn't change the HD stuff for some other $0.50/ft wire unless you were having problems with your current wire.
    If you do want to take a step up, look at Kimber and Audioquest among many others of course. Based on your price range, have a listen and decide what you like. The only problem is if you go bulk, because it's cut to your desire, you probably won't be able to return it if you don't like it.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2004
    I meant that to be lighthearted, just poking fun. I think that if you don't read Roger Russell and the anti-cable brethren, then you are only getting half the picture. Don't get me wrong, I don't disagree with him entirely, all information is good information.
    I've chosen and heard my calling as far as cables go, and I won't be straying from the path anytime soon.
    What you do with it, is entirely on yourself as the user. If 10AWG wire makes you feel good, then it must be good. Good luck in whatever you choose, eventually you will decide on an application that suits you best.
  • Willow
    Willow Posts: 11,283
    edited July 2004
    don't know if it make me feel good to be honest I don't know what if anything that I might be missing say with kimber or audioquest
  • dcarlson
    edited July 2004
    You'd have to give it a try to decide for yourself.
  • Willow
    edited July 2004
    I think so too !! thanks for all the info !!
  • Oldwriter
    Oldwriter Posts: 248
    edited July 2004
    . . .a nice glass of Virgin Islands rum with a big squeeze of lime, and some home-made guacamole - lots of hot sauce. All this mental input has depleted my supply of precious bodily fluids, and thus - well - I thirst! Have a wunnerful eve - - Larry R.
  • dcarlson
    edited July 2004
    That's a system tweak in itself. ;)
