Blew a driver in my RTi A9
Larry51
It appears that I just blew out the very top driver in my RTi A9 (the 5 1/2 incher). I do not see a way to order replacement drivers on this site so I was wondering if the woofer from an R150 would work.
Post edited by Larry51 on
On Monday, CALL (do not email) Polk Customer Service to order a new driver.Political Correctness'.........defined
President of Club Polk -
What kind of power are you running Larry ?
Good question.
@ OP, do you have just an AVR or an external amp?Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I was listening to some Juno Reactor probably. My normal system is to use Rhapsody on my computer hooked to an external USB sound card, then a Rotel RTC-850 preamp and then an old Hafler DH-220 power amp (115 watts/channel). Stereo.
You could probably use some more power for the 9's, just sayin'.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I couldn't have just said it any better
How loud or volume level do you usually listen and did you start hearing distortion?_____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Actually, except for an experiment, I've never driven my A9's with anything less than 200wpc. they've been thriving off 300wpc for some time. Currently, I drive them with 860w.
I'm sorry, did someone say overkill?? Again I'm sorry, I just don't know what overkill means :cheesygrin:Set up: 11.2 HT + 2ch
Geoff, I completely understand you. I started with the A7's with an old Denon AVR and realized more clean power was required. The A9's require more than the A7's. The W4S amp provided a significant amount of more headroom than the Parasound 2250 I was using. With the Parasound, I knew when to lower the volume when the amp started straining. With the W4S, I never feel or hear the ceiling but keep it within reason to not launch one of the tweeters through the opposite wall._____________________________________________________________________________________________
DAC: Bricasti M1SE
LOL, no doubt!!Set up: 11.2 HT + 2ch
At least your girlfriend didn't take out your tweeters 2 days before you upgraded power from AVR to real amp...mine did
I can't even imagine, how ever, my daughter took out my Sammy 64" plasma, the PN8000D with a freaking Wii remote...............ugggggggggSet up: 11.2 HT + 2ch
I guess you can call that foresight. You knew you needed more before you had more power. The hard way! Is she still your girlfriend?_____________________________________________________________________________________________
DAC: Bricasti M1SE
