Blew a driver in my RTi A9
Larry51
Larry51 Posts: 2
edited December 2013 in Troubleshooting
It appears that I just blew out the very top driver in my RTi A9 (the 5 1/2 incher). I do not see a way to order replacement drivers on this site so I was wondering if the woofer from an R150 would work.
Post edited by Larry51 on
    F1nut Posts: 51,943
    On Monday, CALL (do not email) Polk Customer Service to order a new driver.
  • Geoff4rfc
    Geoff4rfc Posts: 2,932
    nbrowser wrote: »
    What kind of power are you running Larry ?
    Good question.
    @ OP, do you have just an AVR or an external amp?
    Set up: 11.2 HT + 2ch
  • Larry51
    Larry51 Posts: 2
    I was listening to some Juno Reactor probably. My normal system is to use Rhapsody on my computer hooked to an external USB sound card, then a Rotel RTC-850 preamp and then an old Hafler DH-220 power amp (115 watts/channel). Stereo.
  • zane77
    zane77 Posts: 1,696
    You could probably use some more power for the 9's, just sayin'.
    Two Channel
  • Geoff4rfc
    zane77 wrote: »
    I couldn't have just said it any better :mrgreen:
  • Thorton
    Thorton Posts: 1,324
    How loud or volume level do you usually listen and did you start hearing distortion?
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Geoff4rfc
    Thorton wrote: »
    Actually, except for an experiment, I've never driven my A9's with anything less than 200wpc. they've been thriving off 300wpc for some time. Currently, I drive them with 860w.
    I'm sorry, did someone say overkill?? Again I'm sorry, I just don't know what overkill means :cheesygrin:
  • Thorton
    Geoff, I completely understand you. I started with the A7's with an old Denon AVR and realized more clean power was required. The A9's require more than the A7's. The W4S amp provided a significant amount of more headroom than the Parasound 2250 I was using. With the Parasound, I knew when to lower the volume when the amp started straining. With the W4S, I never feel or hear the ceiling but keep it within reason to not launch one of the tweeters through the opposite wall.
    DAC: Bricasti M1SE
  • Geoff4rfc
    Thorton wrote: »
    LOL, no doubt!!
  • Geoff4rfc
    nbrowser wrote: »
    At least your girlfriend didn't take out your tweeters 2 days before you upgraded power from AVR to real amp...mine did :(
    I can't even imagine, how ever, my daughter took out my Sammy 64" plasma, the PN8000D with a freaking Wii remote...............uggggggggg
  • Thorton
    nbrowser wrote: »
    I guess you can call that foresight. You knew you needed more before you had more power. The hard way! Is she still your girlfriend?
    DAC: Bricasti M1SE
