SDA-2B and Pioneer M-22 30wpc class A amp
  • hauxon
    hauxon Posts: 161
    edited December 2013
    Ok vintage class A Pioneer looks cool and probably sounds nice with the right speakers (and with my SDA 2B at reasonable listening levels). So I probably need something more than 30 watts. ...how about Adcom 555 II? There's a used one for sale here in Iceland at the moment.
    Hrannar
    SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint
    pitdogg2 Posts: 27,155
    hauxon wrote: »
    Hrannar
    That Adcom has been used and trusted around here go for it....
  • headrott
    headrott Posts: 5,496
    IMO, the Adcom is an OK amp as far as power goes, but (again IMO) is not on the same level of sound quality as the Pass Aleph 30 or BAT VK-200, or even the Aragon 8008bb (all amps I have used personally in my system *recently*). If you are just looking for a quick amp to buy and use, buy the Adcom. If you are looking for an amp to buy keep and love the audio for a long time, I recommend a Pass Labs, BAT, Musical Fidelity, or similar quality amp. The Adcom is not the same quality as Pass, BAT, MF amps, but will get you by. Others may disagree with what I said, but I went down the path you are potentially going to go down hauxon, and I am trying to save you time and money by going for the end product in the beginning, rather than wasting time and money going through steps to get to the end product (high quality audio).
    Of course, it will depend on what other equipment you are using (pairing with the amp).
  • hittlevm
    hittlevm Posts: 3
    heiney9 wrote: »
    Really? You are both wrong on how it would sound, but to the OP no on the negative strapping and yes the right 30 wpc class A amp will sound excellent unless you are trying win an SPL contest or trying to fill a very large room.
    Good call on the 30wpc being enough, it seems everyone these days thinks mega wpc is an absolute necessity. In a
    normal size home/listening room, with a mere watt these speakers can achieve approx. 89-90 decibels. I've used several
    tube amps with 12-14wpc with my 2b's with OUTSTANDING results.
    The key is to be sure you have a preamp that is capable of driving the amp to full power output.
  • hauxon
    hauxon Posts: 161
    2016 has come. In 2013 I decided to skip the M-22 but now I'm able to buy a Pioneer C-21 preamp and M-25 power amp for a resonable price. The M-25 is class A up to 30W and then switches to a 120W AB when more power is needed. Probably better suited for my SDA 2B. ...but I still don't know if it's common ground.
    F1nut Posts: 51,879
    You can buy them, then test the amp to see if it is common ground. If it is not, you can build a Dreadnought. So, nothing to lose except more money.
  • hauxon
    hauxon Posts: 161
    ....So, nothing to lose except more money.
    Exactly! haha
    F1nut Posts: 51,879
    You might want to check over at Audio Karma. They have a dedicated section for vintage Pioneer gear.
  • Nightfall
    Nightfall Posts: 10,083
    Looks like it's capable of sufficiently powering Aiwa boombox speakers. So, there's that.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • hauxon
    hauxon Posts: 161
    The Pioneer M-25 seems be the common ground type but the seller has become difficult so I might just post again in 2019! ... :neutral:
  • hauxon
    hauxon Posts: 161
    It's 2019 and I didn't buy it! hahahaha :smiley:
