SDA SRS Bay Area
Mikey081057
Mikey081057 Posts: 7,127
edited December 2013 in Speakers
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
  • Moose68Bash
    Moose68Bash Posts: 3,843
    I'm glad I no longer live in Palo Alto, or I would almost certainly try to buy these beauties!
    Like I need another pair of SDA SRSs! :-)
    On second thought, everybody could benefit from two pairs!
    I hope a Club Polk member gets them so that they get in good hands, and then Vr3 can do the upgrades.
  • zingo
    zingo Posts: 11,258
    The condition does look good, but they might close for a bit higher price than some of us would want to pay.
  • Irrenhaus
    Irrenhaus Posts: 1,098
    They are asking $1500.00 on Craigslist for the same pair.
    http://sfbay.craigslist.org/pen/ele/4241786640.html
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • LeftCoast
    LeftCoast Posts: 407
    I will be in Northern Cali for the Holidays. Can anyone tell me if the pair will fit in my Nissan Murano?
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Dimensions
    Cabinet Dimensions
    Height 63 1/2" (161.29cm)
    Width 21 3/4" (55.24cm)
    Depth 13 1/8" (33.34cm)
    Product Weight (each) 180 pounds
    Break out the tape measure,see if you have room in the Murano
    Good luck to you.
    Dan
    Here"s where the info was found.
    http://www.polkaudio.com/products/sdasrs12tl
    tonyb Posts: 33,065
    Dan, did you ever pick up those speaks out of San Fran on your way home from smooching with the wife ?
  • Oldfatdogs
    Tony,the guy never replied to my email.But I did have a good time smooching. :)
  • LeftCoast
    Oldfatdogs wrote: »
    Dimensions
    Cabinet Dimensions
    Good luck to you.
    Dan
    Thanks!
    Looks like they will juuuust fit next two each other. I measured 45 inches between the wheel wells.
  • LeftCoast
    zingo wrote: »
    I just realized there are already 10 bids with 14 hours to go. They are sure to go higher.
    Oh well...I saved some money. heheh
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    They are 1.2's because the positive binding post is on the left whereas it should be on the right if they were the original SRS's. There is also a photograph of an addendum the original owner was given referring to upgrading to TL as it mentions MW6503 and MW6511's.
    I'm waiting to hear back from the seller asking them if the interconnect socket is pin/blade. If it is, there is no doubt that they are 1.2's and can be upgraded to 1.2TL's with the appropriate modifications. (Polk Audio never manufactured an original SDA SRS with a pin/blade socket).
    Good to see that the owner ignored the label on the back of the speaker and put the positive binding post nuts on the left thereby avoiding listening to them out of phase. Perhaps the addendum letter stated that he should do that although I'm not sure what the letter said because the resolution of the photograph in the ebay ad is not very good. I can barely make out MW6511 and 6503.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    are they worth it?
    Definitely
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    Irrenhaus wrote: »
    Cheers
    His ad states that they are 1.2 TL's, however, that is incorrect because they still have the SL2000's tweeters in them. At present they are 1.2's which can be converted to TL's by making changes to the crossovers and installing RD-0198's or SL3000 tweeters.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • oldrocker
    oldrocker Posts: 2,590
    They did sell, and a yipper on the "everybody could benefit from two pairs"...
    BTW, them tweeters you sold me are doing just fine...:)
  • michaeljhsda2
    They are indeed 1.2's as the seller said that it has a pin/blade IC socket.
    SDA SRS 2.3TL's
    SDA 2B TL's
