How do you take apart an LSiM speaker?
madmax
madmax Posts: 12,434
edited December 2013 in Speakers
I want to take a look inside, what is the procedure to get them apart?
Vinyl, the final frontier...
Post edited by madmax on
  • deronb1
    deronb1 Posts: 5,021
    pitdogg2 Posts: 27,451
    ummm if it were me I'd use a screw driver......THEN work up to a sawsall
    nooshinjohn Posts: 26,024
    nbrowser wrote: »
    In all seriousness, the Polk website if I recall has some cut away pics in the LSiM product pages, save yourself the work and possibly damaging a great speaker.
    I think this is the best advice... they are build to withstand the prying eyes of mere mortals.
  • seabeerob213
    seabeerob213 Posts: 1,843
    a jump to the left, then a step to the right, put your hands on your hips, and bend your knees in time, and then a pelvic thrust,
    pretty sure thats the method the pros use, FYI: it really drives you insane
  • Loud & Clear
    Loud & Clear Posts: 1,538
    Recently had to do this as I bought a 703 that came with a defective tweeter. The figure 8 rubber piece comes off first - I used a flathead screwdriver to carefully pry back a section and then pulled the whole thing off with my fingers. After that it's just a matter of unscrewing things until you get what you you're after.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
    Toolfan66 Posts: 18,243
    The best way to open them up, is with a good amp..
    Toolfan66 wrote: »
    Now this would be the BEST answer...EVER!!!!
  • dorokusai
    dorokusai Posts: 25,576
    Shotgun.
  • polrbehr
    polrbehr Posts: 2,854
    Great Scott!
    Good advice there...
  • madmax
    Thanks for the info! Is there any particular place where prying would be the safest?
  • JuanR
    JuanR Posts: 718
    Ship the LSiM of your choice (the one you want to have opened) to yourself using one of our wonderful mail carriers (they all will be able to accomplish this act)....
    Inspect upon receipt...
    It couldn't get easier than that!
    VR3 Posts: 29,594
    LSiM-703
    Plastic spoon/fork -
    Midbass/Pry from the outside inwards, middle of gasket, will come off easy
    Tweeter/Midrange - I pried very carefully under the midrange surround, the rubber is adhered on. There is a white piece behind it that has approx. 8 hidden screws that hold everything on.
    There is a crossover at the top and bottom.
    VR3 Posts: 29,594
    JuanR wrote: »
    Now that is impressive, but not out of this world - my LSiM had some inside pieces that had come loose during shipment
  • WLDock
    WLDock Posts: 3,073
    madmax wrote: »
    If these are like other Polk speakers from recent years, they are designed to be assembled quick and easy. So that would me that they should be easy to dissasemble. The "beauty rings" that the LSiM are become more and more common. Most are just press/lock fit and are easy to remove. If you don't have on, get yourseld a plastic/nylon pry bar like these used in this kit:
    Can find them cheap on eBay, Amazon, or a local store.
    VR3 Posts: 29,594
    The LSiM is not what I would call an easy speaker to mess with... the top beauty ring is adhered on but it is a strong rubber
  • smglbrth
    smglbrth Posts: 1,500
    dorokusai wrote: »
    Shotgun.
    Best idea so far...
  • Loud & Clear
    Best not to blow a tweeter on these if you can avoid it. Mine came with a damaged tweeter. Unpleasant to replace. Wiring is very short and this makes for very difficult working conditions. I had to use a phillips head drill bit to screw the tweeter into its bracket with my fingers. Not ideal.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • drummer86
    drummer86 Posts: 441
    DSkip wrote: »
    Throw it against the wall.
    deronb1 wrote: »
    Circular saw?
    dorokusai wrote: »
    Shotgun.
    Is it just me or is everyone around here especially ornery lately? Loving these responses!
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
    txcoastal1 Posts: 13,519
    VR3 wrote: »
    Maybe they were trying to make them VR3 proof
