5.1 vs 2.1
RodneyWoodford
Is there a big difference in using a 5.1 receiver in 2 channel mode vs a 2.1 stereo receiver. Was looking at buying a new Harman Kardon or a Marantz running a couple of Rti 10's. Thanks for any info.
Post edited by RodneyWoodford on
So a 5.1 using only 2 channels would be just as powerful as a 2 channel receiver?
depends on the receiver, look at the 2 channels driven power rating in the specs2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
So a 5.1 driven on 2 channels 80 watts per channel is as good as a 2 channel receiver at 80 watts per channel?
RodneyWoodford wrote: »So a 5.1 driven on 2 channels 80 watts per channel is as good as a 2 channel receiver at 80 watts per channel?
It's not that simple, all watts are not created equal and in fact, it's more about current than watts per channel. A 2 channel receiver is likely to have a better power supply than your average AVR, but it's still a receiver. Unless you need a tuner, you'd be much better off getting a nice 2 channel integrated amp.Political Correctness'.........defined
President of Club Polk -
Don't need a tuner , any suggestions on a 2 channel integrated amp. Around $500. Thanks
You should be able to pick up a used NAD or Cambridge in that price range. If you doubled that, there's a lot more to consider. I noted you mention 2.1, are you using a sub?Political Correctness'.........defined
No sub. Hoping to run a blu ray to play dvds and cds also a sat receiver and out to tv. Is this possible? Only want 2 channels using Rti 10's.Can you run HDMI out to amp and out to tv?
In that case you will need an AVR.Political Correctness'.........defined
Thanks F1nut!!
AVRs also carry the benefit of room correction software that stereo receivers and integrated amps do not. Not the end all be all but very helpful especially with movies in less-than-ideal rooms.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player
