5.1 vs 2.1
RodneyWoodford
RodneyWoodford Posts: 144
edited December 2013 in Electronics
Is there a big difference in using a 5.1 receiver in 2 channel mode vs a 2.1 stereo receiver. Was looking at buying a new Harman Kardon or a Marantz running a couple of Rti 10's. Thanks for any info.
Post edited by RodneyWoodford on
  • RodneyWoodford
    So a 5.1 using only 2 channels would be just as powerful as a 2 channel receiver?
  • seabeerob213
    seabeerob213 Posts: 1,843
    depends on the receiver, look at the 2 channels driven power rating in the specs
  • RodneyWoodford
    So a 5.1 driven on 2 channels 80 watts per channel is as good as a 2 channel receiver at 80 watts per channel?
    F1nut Posts: 52,152
    It's not that simple, all watts are not created equal and in fact, it's more about current than watts per channel. A 2 channel receiver is likely to have a better power supply than your average AVR, but it's still a receiver. Unless you need a tuner, you'd be much better off getting a nice 2 channel integrated amp.
  • RodneyWoodford
    Don't need a tuner , any suggestions on a 2 channel integrated amp. Around $500. Thanks
    F1nut Posts: 52,152
    You should be able to pick up a used NAD or Cambridge in that price range. If you doubled that, there's a lot more to consider. I noted you mention 2.1, are you using a sub?
  • RodneyWoodford
    No sub. Hoping to run a blu ray to play dvds and cds also a sat receiver and out to tv. Is this possible? Only want 2 channels using Rti 10's.Can you run HDMI out to amp and out to tv?
    F1nut Posts: 52,152
    In that case you will need an AVR.
  • RodneyWoodford
    Thanks F1nut!!
  • drummer86
    drummer86 Posts: 441
    AVRs also carry the benefit of room correction software that stereo receivers and integrated amps do not. Not the end all be all but very helpful especially with movies in less-than-ideal rooms.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
