What center with LSi7's?
jawhog
jawhog Posts: 444
edited July 2004 in Speakers
I've seen all the posts about using LSi7's all around, etc.
My Yamaha receiver can handle 4--ohm mains, but the center or rears have to be 8-ohm.
Who's using their LSi7's with a non-LSI center and how happy are you with it?
  • amulford
    amulford Posts: 5,020
    edited July 2004
    Just because you don't want to run 4 ohms doesn't mean you can't use the LSiC. You could still run it if you keep the SPL levels down, You put in a four Ohm resistor in line to boost the resistance. Not a big deal. IMHO, I wouldn't want to run anything else, the timbre match wouldn't be there. Especially in the front stage.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited July 2004
    I am - timbre match is very acceptable, but not perfect.
    SVS
