My DIY audio rack.
bored184
Below is a photo to my new audio rack. I took two old chemistry lab tables and shortened them up a little. The wood will eventually be stripped and stained. The tops will get a few more coats of primer and sealer. Next summer I am thinking of staining the wood a cherry color and giving the tops a polished black look.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
Post edited by bored184 on
That looks really solid, you could pile a ton of gear on those, nice DIY project.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
That came out very nice._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
I prefer the finish just the way it is man. Spike em and call it a day."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Looks real solid, what are the top and shelf made out of? I agree...looks great as is.
If they are old lab tables, then my guess might be some sort of epoxy finish on top or something? They look like my high schools old chemistry tables. Which were sturdy as heck and put up with lots of spilled chemicals, so it should make a nice table."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Love it.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Awesome!!! Repurposed stuff like that is always cool. Great idea.Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables -
I had my father make up some metal sleeves for carriage bolts. I cant quite spike them so I figured the rounded end on a carriage bold is the next best thing. Also with the help of a nut it allows me to level the audio rack. I will try and get some photos of the legs when I start that process for those of you who want to copy the idea.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Pre: Adcom GFP 750, Aikido Tube Pre -
Great DIY Rack, Solid! The chem lab tables I used in college had hard black (chemical resistent) rubber tops.
I like your idea of using stove bolts vs spikes, interesting thought.
Regards: Don ScheerDonto's System:
Parasound HCA3500
Parasound HCA 1500a (4 each)
DIY Set Tube Amps (4 each)
Parasound 850 Pre-Amp
Onkyo CD Player
Teac Tape Play/Recorder
Samsung 50" TV
Toshiba HD DVD Play/Recorder
Polk RTA12C Speakers
DIY 15" Side-Firing Subwoofers (2 ea)
DIY 15" Down-Firing Subwoofer
Adcom Power Conditioner
DIY Isolation Transformers/Power Conditioner
4 ea 20 Amp Power Circuits -
Very nice. Bet it weighs a ton.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Nice re-purposing!
