RTia9 vs LSI9's
  • Ginn
    Ginn Posts: 46
    edited November 2013
    Thx guy's,
    I'll try and pull the crossover out soon and post a pic.
    Cheers.
    HT - Sony 52" Bravia - Onkyo TX-NR3008 - Emotiva XPA-5
    LSi15 - LSiC - LSifx - PSW505 - Mac Mini
    Warehouse Boxed up RTIa9 - CSIa6 - FXI6
    Office
    LSI15 - Peachtree Preamp / 220 - iMac
    LSi9's sitting around my dad's house
  • Ginn
    Ginn Posts: 46
    So I pulled the crossover out and you were right. The 5w resistor looks burnt all around it. I took a couple pic's but I have no idea how to upload them onto this forum.
    Any suggestions to a resistor to replace it with? Upgraded?
    Cheers…..
    Office
    txcoastal1 Posts: 13,513
    sent you PM...I will post photo
    Here is Ginn's burnt and cracked resistor
    F1nut Posts: 51,789
    Ginn wrote: »
    Cheers…..
    That's the one, told ya it would be easy to spot. :wink:
    Replace them with Mills 12 watt in whatever the ohm value is. They are available from, http://www.soniccraft.com/
  • Ginn
    Ginn Posts: 46
    Thanks F1.
    So I pulled the other speaker apart and the resister was not even attached on one terminal.
    So all the numbers on the resistor is faded off. I think it says (ph)5w3roj or (ph)5w1roj.
    I don't know which one. The centre channel is the 1roj but I think the lsi9 is a 3roj.
    Any feedback on this one? I don't know what ohm that would make it. The speaker is a 4ohm speaker but I don't know about the resistor.
    Office
  • Ginn
    Ginn Posts: 46
    This is what the other crossover looked like
    Office
    F1nut Posts: 51,789
    The resistor value has nothing to do with the nominal impedance of the speaker. Since you are in there, might as well replace all the resistors. It will improve the sound a bit and they are cheap enough.
    Stock values:
    LSi 9 tweeter - 3 ohm/5 watt
    LSi 9 upper driver - 1 ohm/10 watt
    Replace with Mills
    3 ohm/12 watt
    1 ohm/12 watt
    Stock values:
    LSiC tweeter - 1.5 ohm/5 watt
    LSiC left driver - 1 ohm/5 watt
    Replace with Mills
    1.5 ohm/12 watt
    1 ohm/12 watt
  • Nightfall
    Nightfall Posts: 10,084
    They don't burn out crossover boards. There is a 5 watt resistor in the high frequency circuit that in hindsight should have been of higher wattage. It can cook given volume abuse.
    Yes, all the ones I've seen have just needed the resistor replaced. Something like a Mills 12 watt will do the trick. Of course, if some bozo is cranking his AVR into clipping causing the 5 watt resistor to cook, the higher wattage resistor will allow the tweeter to fry.
    You don't know what resistor to use?
    afterburnt wrote: »
    Village Idiot of Club Polk
    tonyb Posts: 33,072
    Very good point Jess, and second that suggestion.
    F1nut Posts: 51,789
    tonyb wrote: »
    But, apparently I don't know what resistor to use. :eek:
    I'm sure VR3 does......hey Trey
  • Ginn
    Ginn Posts: 46
    Thanks F1
    I'll take your advice and replace all of them.
    I'll try to find those around town today. If not I'll have to order online and have them shipped up.
    Now I'm starting to think since I'm in there, I might as well change the caps.
    Office
    F1nut Posts: 51,789
    txcoastal1 wrote: »
    Seriously? You must have missed post #43.
    yep.....u da man
  • Ginn
    Ginn Posts: 46
    So I finally got the resistors shipped and installed.
    They sound 100% better than before. It was the resistors that were blown so I put in the Mills as F1 suggested.
    Question for those with a LSIC. Do you notice a different sound coming out of both drivers? I notice that voices and higher end sound come out of the right driver and tweeter, but mostly lower sounds and no voices come out of the left driver.
    I compared it with my CSia6 and the a6 throws out the same sound out of both drivers.
    Anyone have any experience with this?
    Office
  • Inspector 24
    Inspector 24 Posts: 1,308
    Hey Ginn, got your PM, not sire I've noticed this, but I do know some centers have the drivers crossed over differently.
    I seem to recall discovering this on other Polk centers, can't remember which. I'll check tonight after dinner. I also have a CS1000 I can check. :p
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Ginn
    Ginn Posts: 46
    Thank you sir. Just want to know for sure after installing the new resistors.
    Office
