Build in Squeezebox
polk500
So I thought about doing this for awhile now. As I have all the audio equipment in a closet I missed looking at the Squeezebox it was convenient as a clock As the meters:cool:
So I spent a couple of hours this afternoon build a little box spray bombed it glossy black.
Mounting it was easy cut out the drywall put in place trimmed it out and secured it with braid nails.
I would have liked to centre it more but the framing determined it's final position.
I took a couple of pictures but as everything is glossy black not much detail to see.
I mounted high so it easy to use which is kind of cool cuz usually I use a app.
Cheers
Roger
Cheers
Roger
Post edited by polk500 on
Very cool solution!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
that is cool! in case u didn't know; there's an app for weather and stuff..might be cool when it's idle
Thanks Guys, and I didn't know about the app I will check into it.
Cheers
Roger -
Mike I downloaded the weather app when I was home for lunch and it says it's installed but I can't find it anywhere in the settings, apps etc. any suggestions or am I just plain dumb
Roger -
Roger
Are you looking in the squeezebox control panel program on your computer, or on your phone?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
On the squeeze itself.
thanks
Roger
