Build in Squeezebox
polk500
polk500 Posts: 1,171
edited November 2013 in Electronics
So I thought about doing this for awhile now. As I have all the audio equipment in a closet I missed looking at the Squeezebox it was convenient as a clock As the meters:cool:
So I spent a couple of hours this afternoon build a little box spray bombed it glossy black.
Mounting it was easy cut out the drywall put in place trimmed it out and secured it with braid nails.
I would have liked to centre it more but the framing determined it's final position.
I took a couple of pictures but as everything is glossy black not much detail to see.
I mounted high so it easy to use which is kind of cool cuz usually I use a app.
Cheers
Roger
Post edited by polk500 on
