Problems with the forum
drumminman
drumminman Posts: 3,396
edited November 2013 in Troubleshooting
Hey Mods,
I'm unable to reply to pm's or upload pics.
Thanks,
Fred
Post edited by drumminman on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited October 2013
    Hi Fred,
    Let me send this to Polk's IT guy.
    Regards, Ken
  • drumminman
    edited October 2013
    Thanks Ken!
    F1nut Posts: 51,763
    edited October 2013
    Fred, there's all kinds of problems here that are affecting folks in different ways. I can't directly quote anyone or edit my posts, which Ken knows about. I can PM, but haven't tried uploading any pics.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2013
    Drumminman, I've had just some minor problems w/ the forum. I can both send and receive p/m w/o any problems.With the exception of incoming friend requests and I'm unable to reply to these and then these peeps think I'm anti social and that's not the case here. i've posted a boatload of pix on regular threads but have no idea how to post a pix for a p/m or even if it's a feature that's available which I think is pretty important. If you want to show a particular member your progress on mods or whatever and not the entire forum I think that should be something that we should be able to do unless I missed it entirely....lew
  • [Deleted User]
    edited October 2013
    According to Polk the problems (drumminman's at least) should be better.
    EndersShadow Posts: 17,704
    edited October 2013
    Jesse, have you tried switching your forum view to "test" instead of red/gray down at the bottom?
    I found when I did that while the color changed to a stock blue and white, I got a LOT more options back for replying and such.
  • Hermitism
    Hermitism Posts: 4,329
    edited October 2013
    When I'm on my android tablet, some pages won't load. They are just blank white pages and I have to refresh the page repeatedly before the page shows up. It seems to happen randomly. It happens using the stock browser which I don't use all the time. Never happened before the forum upgrade.
  • decal
    decal Posts: 3,205
    edited October 2013
    That worked for me also.
    F1nut Posts: 51,763
    edited October 2013
    Ok, switched to test, so let's see what happens.
    F1nut Posts: 51,763
    edited October 2013
    That didn't work, I still cannot edit or quote :(
  • drumminman
    edited October 2013
    It's weird how different members are affected differently. I can edit and quote, no worries. Per Ken's comment above, I'm going to see if I can post a pic.
    Drat! Still not working, tried test mode too.
    edited October 2013
    Well lets be honest here Jesse... you dont need to quote anymore.... just quoted :biggrin:
    What browser are you using, and have you cleared your temp internet files and cookies?
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited October 2013
    I can do everything, but I am viewing the forum in "test" mode.
    F1nut Posts: 51,763
    Well what do you know, everything is working again. :smile:
    treitz3 Posts: 19,989
    The mobile side of things are still astray, unless I'm doing something wrong. When I go to reply to a post and start typing, the keypad comes up and then slides right back down.....which means I can't respond via mobile. Anybody know if this is on Polk's forum [or vBulletin] side of things or possibly some sort of setting or issue on my end?
  • BlueFox
    BlueFox Posts: 15,251
    Seems okay from the iPhone and iPad. I am using the 'Test' motif.
  • BlueFox
    BlueFox wrote: »
    Reply with quote seems to work from iPhone.
    Thanks Bluefox. Unfortunately that didn't work. It does the same exact thing. No issues on another vBulletin forum but that doesn't mean that an issue still may not exist on my end of things. I can't see any settings that I can change to prevent this from happening. Using a Windows8 mobile device(s).
  • Hermitism
    How are you guys still posting pictures? I no longer have a button to upload pics.
  • BlueFox
    Hermitism wrote: »
    You need to use the 'Test' motif, at the bottom of the page.
    On quick reply, scroll over the "picture icon" and either upload from your computer or choose the URL option and insert the link. Or you can just use code. [IMG ][/img]insert URL here . Just have no space after the capital "G" in the first . You may have to be on the "test" motif as mentioned to see the quick reply options.  Tom
  • Hermitism
    Ahh! I found it! I couldn't figure out where the "test" button was. Thanks!
