Using a switched outlet on a vintage receiver
Easy Runnin
Easy Runnin Posts: 501
I would like to plug a newer CD player into the switched outlet on a vintage receiver but the CD plug has a wider prong and the receiver will not accept it. Is there a preferred adapter for this type of situation?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
    pitdogg2 Posts: 27,055
    edited October 2013
    It's called a wall outlet. Chances are a cheater plug will also have the polarized plug also.
  • zane77
    zane77 Posts: 1,696
    edited October 2013
    A file can change the shape of the polarized plug easy enough
    Two Channel
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited October 2013
    As a rule of thumb never use the plugs in the back of a vintage reciever for obvious reasons ( old,vintage may not be up to snuff ect.) . Use a surge resistor and plug everything into that.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Glen B
    Glen B Posts: 269
    edited October 2013
    zane77 wrote: »
    Seconded. I would not recommend it for lighting and power-transformerless equipment, where the neutral side may be connected to the metal case, but on gear like a CD player it is fine to file down the wider prong. The current draw of the average CD player is at most about 250mA-300mA at 120V, and not an issue being powered from a switched outlet of a vintage receiver.
    tonyb Posts: 33,072
    edited October 2013
    Personally I wouldn't do it, and over 40 years in Audio have never seen anyone do it either.
  • Boonaroo
    Boonaroo Posts: 57
    edited October 2013
    I have filed polarized plugs down also. I haven't experienced any problems.
  • 20hz
    20hz Posts: 636
    edited October 2013
    I used to run a extension cord off a switched outlet to multiple things operate small stuff like a cd player turntable etc just make sure you dont take a lot of power from that plug most are marked and if you use only one item at a time you should be safe ,
    the polerized plug was added for safety
