Power question
Nightfall
F1Nuts suggestion to nbrowser (Edit: In another thread, obviously) put a question in my mind.
At what point, concerning amplification, is a dedicated line off the circuit breaker necessary? I assume you can't just say x amps can supply x watts? How do you know how many amps an amplifier is pulling from the wall?
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk
Post edited by Nightfall on
While power can play a part in getting a dedicated line, I suspect the main reason for a dedicated line is to eliminate as much noise pollution as possible from the line. With a shared line, everything plugged into it is putting noise onto the line. Of course, this noise can go back to the breaker, and then leech in on the dedicated line, but it is probably less than being on the same circuit. When I had my dedicated line installed the audio improvement was obvious by making the background quieter, and sounds more defined.
One other benefit of a dedicated line is you reduce the number of potential DTCD drops, but this is a new concept and is still being quantified through research.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Any audio rig will benefit from a dedicated line regardless if it's an AVR, 100wpc amp or a 500wpc amp. It's not just about being able to supply the power it's also about lowering the noise floor.I assume you can't just say x amps can supply x watts?
Yes, you can. For example, a 15 amp line can provide 1800 watts, less the 20% margin required by code for 1440 watts. So, if you have a power amp that has a maximum draw of 1500 watts, you really need a 20 amp/2400 watts line less 20% for 1920 watts. Keep in mind that you also have to use the proper gauge wire. A 20 amp line requires at a minimum 12/2 wire, but you could use 10/2 if you wanted.
That said I'm going to repeat myself, it's not just about being able to supply the power it's also about lowering the noise floor.Political Correctness'.........defined
President of Club Polk -
Understood, thank you guys!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
F1NUT did a good job explaining the reasons why for a dedicated line and clean power but let me add to that. While true, that any system can benefit, most systems can use a dedicated 15 amp line already available in your home.....as long as you don't have other huge current drawing appliances on that line or noise inducing lights. If your worried about wattage usage, lets keep in mind an amp stores power, it doesn't use it's full rated power all the time the second you turn it on.
I certainly realize dedicated lines are optimal, but not practical for some of us. A good power conditioner can also offer up some benefit in line noise rejection for those who adding dedicated lines is out of the question. Plus, change out those old standard wall sockets the builder installed to at least a hospital grade receptacle or PS Audio if you want to go a few notches above that. If you combine those 2, a good power conditioner and upgraded wall sockets, your going to realize and hear what a lower noise floor does for your music.HT SYSTEM-
lsi 9's -
+1 on the noise. I did 2 dedicated 20 amp lines a couple months ago. I hadn't been tripping breakers or anything before, so I was wondering if I'd see any improvement. The noise was the difference, or more accurately the lack thereof. Background noise I really didn't think was there...until it was gone. And with adding amps, subs and such, it's a nice feeling not to be taxing the power coming in.
Would there be any negative implications of (GOING Bigger) installing a home-run/dedicated circuit to your Rig using 10 AWG and equally rated recepticles ??AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Nope it would be a no harm what so ever,and give just that much more insurance to free flowing electrons -
Better is running a heavy wire dedicated circuit from the main breaker box to a central point in your room. Then star out to the equipment outlet boxes. Shorter runs between your components is better than longer runs.
And yes you can (and sometimes you must) use 8AWG or 10AWG in a 15A or 20A circuit.
There is no internal difference between a 15A and a 20A dual receptacle. In either all the internal parts are rated at 20A. -
10 gauge is a bit more difficult to work with, but other than that there is no downside. It will also allow you to use a 30 amp breaker.Political Correctness'.........defined
I'm assuming a lower noise floor = a more transparent presentation?
That and mo' better bass.Political Correctness'.........defined
The NEC code problem with a 30 Amp breaker circuit is that you cannot use 20A or 15A receptacles.
In most cases a 15amp breaker would suffice so you can use those standard 15A Hubble hospital grade recepticles.Speedskater wrote: »The NEC code problem with a 30 Amp breaker circuit is that you cannot use 20A or 15A receptacles. -
I'm assuming a lower noise floor = a more transparent presentation? I've looked at sockets, but will not do any bigger electrical work as my system is in the 4th bedroom. Our second home will probably get a dedicated 20 amp line, but its not worth the investment here.
Yes, that's it exactly, a more transparent presentation. There is blackness now where I wrongly blamed some of the "software" before. -
Dk ??AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Don't tell them and all is good. If you ever sell your house just swap in a 20 amp breaker.Political Correctness'.........defined
the NEC is all about protecting life & property. If working properly, the weak link (breaker/fuse) would "open" before hazard happens . . . but what do I know . . . sounds like all should be okay dokay??
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
