Will this be OK ????
pumpkinman
The new drivers have finally arrived for my 3.1 TL's. I've read about the problem of under powering the SRS line.
Sansui AU-9500
Form Integrated Amplifier
Output power Music power (IHF): 260W (4ohm, 1kHz)
Effective output (one-side-channel operation): 85W/85W (8ohm, 1kHz)
Effective output (both channel operation): 80W+80W (8 ohm, 1kHz)
Succession effective output (both channel operation, the rated distortion of 8 ohm, 20Hz - 20kHz): 75W+75W
Sansui AU-9500
Because I am The Pumpkinking
Post edited by pumpkinman on
You'll get sound, but the performance will be no where near what those speakers are capable of.Political Correctness'.........defined
President of Club Polk -
Sometime next week I'll move the Vandersteen 3A's out and put in the Polks where there is 270 wpc. I was concerned about possible damage ??
As long as you don't rock out, it should be safe.Political Correctness'.........defined
I don't play music as loud as I use to.
pumpkinman wrote: »I don't play music as loud as I use to.
The older I get the louder I have to play it, my ears aren't as good as when I was young
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
That's a 75-watt integrated amplifier, that's had the specifications "juiced" to justify a 260-watt addendum to the chart.pumpkinman wrote: »Sometime next week I'll move the Vandersteen 3A's out and put in the Polks where there is 270 wpc. I was concerned about possible damage ??
Keep in mind that like ALL older equipment, it may not now be in condition to even meet the factory specs. The capacitors in particular may be "tired".
Absolutely.You'll get sound, but the performance will be no where near what those speakers are capable of. -
Just confirm the 270 wpc is common ground.pumpkinman wrote: »Sometime next week I'll move the Vandersteen 3A's out and put in the Polks where there is 270 wpc. I was concerned about possible damage ??
McIntosh MC7270 and I was told it is common ground.
Anyone know different ??
The MC7270 would be the better choice.Denon PMA-900V
Linn Axis with Grado Red
Cambridge Azur 650C
Polk SDA-1BTL -
Your ditching Vandersteen 3As for Polk SDAs that pretty impressive right there.Your Mac should have no problem pushing them at all and like Jesse said maybe watch it on the volume side. My Adcom at 200 a side works wonders on my 2Bs, so you should be more than ok even w/ the bigger speakers.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: »Your ditching Vandersteen 3As for Polk SDAs that pretty impressive right there.Your Mac should have no problem pushing them at all and like Jesse said maybe watch it on the volume side. My Adcom at 200 a side works wonders on my 2Bs, so you should be more than ok even w/ the bigger speakers.
Not necessarily so. But to do a comparison I want to use the same system. I fell in love with the 3A's and is doubtful they'll be knocked off their perch.
The V's are quite good but if you really like "SDA" then they are just regular speakers.pumpkinman wrote: »Your ditching Vandersteen 3As for Polk SDAs
Not necessarily so. But to do a comparison I want to use the same system. I fell in love with the 3A's and is doubtful they'll be knocked off their perch.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I find the opposite to be true. I don't play things as loudly as I did in my youth. It bothers my ears more and I also fear for my hearing.
Looks like a nice set up, above! Those old Sansuis sound very "nice" but they're not the best choice for powering SDAs which are hungry speakers!
That said, that's an absolutely "gorgeous" Sansui! How about getting a pair of Monitor 7s on it? Bet that would sound fantastic!
Enjoy!
Well moving the Vandersteens and replacing them with the Polk's will have wait a bit. While visiting my sister this weekend the new dog decided my hand looked like a milk-bone. The little **** bit me !! Hopefully I'll be able to swap them out over the coming weekend.
Ouch... darn dog.
