Will this be OK ????
pumpkinman
pumpkinman Posts: 10,238
edited October 2013 in Vintage Speakers
The new drivers have finally arrived for my 3.1 TL's. I've read about the problem of under powering the SRS line.
Sansui AU-9500
Form Integrated Amplifier
Output power Music power (IHF): 260W (4ohm, 1kHz)
Effective output (one-side-channel operation): 85W/85W (8ohm, 1kHz)
Effective output (both channel operation): 80W+80W (8 ohm, 1kHz)
Succession effective output (both channel operation, the rated distortion of 8 ohm, 20Hz - 20kHz): 75W+75W
Because I am The Pumpkinking
Post edited by pumpkinman on
    F1nut Posts: 51,794
    edited September 2013
    You'll get sound, but the performance will be no where near what those speakers are capable of.
  • pumpkinman
    Sometime next week I'll move the Vandersteen 3A's out and put in the Polks where there is 270 wpc. I was concerned about possible damage ??
    F1nut Posts: 51,794
    As long as you don't rock out, it should be safe.
  • pumpkinman
    I don't play music as loud as I use to.
  • gimpod
    gimpod Posts: 1,793
    pumpkinman wrote: »
    The older I get the louder I have to play it, my ears aren't as good as when I was young :)
  • Schurkey
    Schurkey Posts: 2,122
    pumpkinman wrote: »
    That's a 75-watt integrated amplifier, that's had the specifications "juiced" to justify a 260-watt addendum to the chart.
    Keep in mind that like ALL older equipment, it may not now be in condition to even meet the factory specs. The capacitors in particular may be "tired".
    Absolutely.
  • Mystery
    Mystery Posts: 2,546
    pumpkinman wrote: »
    Just confirm the 270 wpc is common ground.
  • pumpkinman
    Mystery wrote: »
    McIntosh MC7270 and I was told it is common ground.
    Anyone know different ??
  • bigaltx24
    bigaltx24 Posts: 141
    The MC7270 would be the better choice.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • leftwinger57
    leftwinger57 Posts: 2,917
    Your ditching Vandersteen 3As for Polk SDAs that pretty impressive right there.Your Mac should have no problem pushing them at all and like Jesse said maybe watch it on the volume side. My Adcom at 200 a side works wonders on my 2Bs, so you should be more than ok even w/ the bigger speakers.
  • pumpkinman
    Not necessarily so. But to do a comparison I want to use the same system. I fell in love with the 3A's and is doubtful they'll be knocked off their perch.
  • PolkieMan
    PolkieMan Posts: 2,446
    The V's are quite good but if you really like "SDA" then they are just regular speakers.
    pumpkinman wrote: »
    gimpod wrote: »
    I find the opposite to be true. I don't play things as loudly as I did in my youth. It bothers my ears more and I also fear for my hearing.
    Looks like a nice set up, above! Those old Sansuis sound very "nice" but they're not the best choice for powering SDAs which are hungry speakers!
    That said, that's an absolutely "gorgeous" Sansui! How about getting a pair of Monitor 7s on it? Bet that would sound fantastic!
    Enjoy!
    cnh
  • pumpkinman
    edited October 2013
    Well moving the Vandersteens and replacing them with the Polk's will have wait a bit. While visiting my sister this weekend the new dog decided my hand looked like a milk-bone. The little **** bit me !! Hopefully I'll be able to swap them out over the coming weekend.
  • Mystery
    edited October 2013
    Ouch... darn dog.
