Hows this system sound?
  • AintJoM0mma
    AintJoM0mma Posts: 131
    edited June 2004
    Which is why I went to Tweeter twice this week...
    I = NOOOOOOoooooo000b
    VR3 Posts: 29,397
    edited June 2004
    Dude,
    I have the SVS PCI 22-31 (25-31, free 22hz tune)
    YOU WILL NOT******************************* in a 10x10 room, and I repeat.... WILL NOT!!!!!!!!! Need ANYMORE bass in THAT room.
    My sub hits down to 15hz at 81 db (starting at 85db at 100hz) --
    It is EXTREMELY loud --- save your money and get it. You will get the SPL and the extention in that room, without a doubt.
    I suggest you just listen around --
    Polk Audio, Axiom, Definitive, Infinity, Boston, Klipsch, B&W, JM Lab, there is A BUNCH of speakers in that price range ---
    Adcom, NAD, Denon, Yamaha, Sony ES, Pioneer Elite, AMC, etc etc - Bunch of amps and receivers out there
    SVS, HSU are subwoofers to look at
    CD Players -- I like Denon sources personally
    But from the system standpoint above - I would go with what you said but with the subwoofer I suggest above, you get the SPL still and the extention.
