40 watt amp with two 150 watt speakers?
I'm trying to set up a small speaker system for my TV, and I was looking around for things to buy and came up with this setup:
http://www.amazon.com/Pyle-PTA2-2x40W-Stereo-Amplifier/dp/B0013CDZDI/ref=cm_rdp_product
with
http://www.amazon.com/Sony-SSF-5000-Floor-Standing-Speaker/dp/B000OG4E1G
Here are the basic stats for the amp,
2 x 40 Watt RMS at 4 Ohm
Frequency Response: 20 Hz-20 kHz
and the basic stats for the speakers:
Frequency Response Curve 45-50,000Hz
Audio Sensitivity 88 dB
Impedance 8 ohm
Now, I researched this a bit, and I was worried about the fact that the amp is only 40 watts per channel. I read a lot of things and understand that the speaker wattage is the max wattage, and that 40 watts should actually be plenty to handle for this setup, but I just want to make sure.
Anybody have any input on whether this is an okay setup or the two things don't match up?
Post edited by like45ninjas on
