I Am A Believer ...The MIT Mania
Sumerian
Sumerian Posts: 490
edited September 2013 in Speakers
When i initially started this Audio journey, i built a budget system and everything was in budget but i never regretted any choice/decision i made.
I still think my AVR and my speakers were good for the money
One decision i really regret now is the Monoprice cables though they are cheap
I regret that i thought all cables same.... Like a freaking frog in a well.
With the recent speaker upgrade i wanted to jump out of that well and explore the new world ... Thanks for F1Nut for pulling me out...
"buy MIT and thank me later" so here it goes .....Thanks Jesse!.
i am close to that 200 hours of burning my shotgun S3 speaker cables with my LSIM's....
instead of using all sorts of adjectives to describe how much i liked them let me just tell you guys that I used my last few hundreds (of my audio budget )to place order for Shotgun S3 RCA cables to connect High end HTPC to AVR.
High price items may not mean high quality but high quality items never comes cheap ..... PERIOD (.)
and yeah i am giving my Monorpice cables to the folks who purchased/purchasing my old speakers He He :evil:
Post edited by Sumerian on
    F1nut Posts: 51,691
    I'm glad they are working out for you.
  • brgman
    brgman Posts: 2,859
    Another lost soul has found the way.
    Reverend Jesse pulls another from the depths of audio despair!
    Congratulations
    I’M OFFENDED!!!!
  • GlennDog
    GlennDog Posts: 3,149
    High price items may not mean high quality, but high quality items never come cheap ..... PERIOD (.)
    Very true . . .
    My MITs should be here today. I'm really geeked!
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Sumerian
    Sumerian Posts: 490
    Yup waiting on my RCA's
    Decided to uprade all the IC's and Cables before getting any new components.
    I wish i have enough dough to get a MIT cable for surrounds too.
  • WLDock
    WLDock Posts: 3,073
    Good hear they worked out for you.
    As far as using the MITs for the surrounds? Man would that be a lot for surround cables...
    Have you considered other ways to improved the rear? What about trying to pull off that last bit of surround performance compairing the LSiM702 f/x to the 703's on the sides? Or go full 7 ch?
  • Sumerian
    Sumerian Posts: 490
    WLDock wrote: »
    Even though its been ages since I've heard an MIT cable and have yet to hear the Shogun S3's IMO, I think using them for the surrounds would be the very last thing I would do (if at all) if all else was in place and I was bored and had extra cash on hand. I think I would want to see how much better I could create a more enveloping surround experience. Before I spent that much on surround cables I would have to try the LSiM702 f/x vs. the 703's on the sides in a 5 ch system or try a 7 ch system with the 702's on the side and the 703's in the rear....to see if I could pull off that last bit of surround performance.
    Agree with you... some time in near future i am thinking of going with (douglas connection or signal cable for surrounds) which ever offers a decent disocunt for Polk members.
    Toolfan66 Posts: 17,995
  • Sumerian
    Sumerian Posts: 490
    Toolfan66 wrote: »
    Sucker!!!
    For ?!
    Enjoy. A friend's daughter is in her second year at the "real" MIT, you know, that relatively unknown Science and Engineering school in Cambridge, Mass.
    cnh
    EndersShadow Posts: 17,687
    Sumerian wrote: »
    Both offer the same discount percent off IIRC and I believe (but don't quote me) its 10%. Are you looking for speaker cable and interconnects for your rears, or just speaker cables?
  • Sumerian
    Sumerian Posts: 490
    Just speaker cables for surrounds only
    txcoastal1 Posts: 13,500
    F1nut Posts: 51,691
    Sumerian wrote: »
    For ?!
    He's joking with you. Larry uses MIT cables as well.
  • Sumerian
    Sumerian Posts: 490
    Unfortunately for me i miss the jokes on the forums... I think i need better cables in my head LOL.
    f1nut wrote: »
    he's joking with you. Larry uses mit cables as well.
    ;-) yep!!!! LOVE "EM"
    Sumerian wrote: »
    Wow that is almost close to Monoprice cables price...
    Yeah, if you DIY using his connectors and speaker wire its about monoprice price wise, but much much much better sound wise :).
    Give him a call, he's a great guy and he can give you the in and outs of his cables, but I like em myself....
  • Sumerian
    Sumerian Posts: 490
    Ok so it has three times better quality than mono price ? LOL.
    thanks for the advice will ring him up.
    Sumerian wrote: »
    At least :biggrin:. Cant say enough good stuff about both him and his cables :smile:. Personally I prefer his spades over banana's.
  • Nightfall
    Nightfall Posts: 10,084
    Doesn't Doug use Canare?
    afterburnt wrote: »
    Village Idiot of Club Polk
    Nightfall wrote: »
    Nope, Furez
  • Upstatemax
    Upstatemax Posts: 2,735
    I also had my "enlightenment" moment with MIT. I jumped on the Exp2 sale and hooked them up to my old RTi A7's and was in love.
    I would have kept them but I did not care for the laid back top end that I got out of them on my LSi's after I had to consolidate systems. I decided to keep my Signal Ultra's that I found to be more neutral.
    Sadly, my surrounds are still hooked up with Monoprice wire...
    I need to take the time to just order the Douglas wire and be done with it!
  • B Run
    B Run Posts: 1,888
    I snagged the same MIT Exp2's for my HT and think they're great bang for the buck. I agree the top end is laid back and I think it balances out the Rti's perfectly, but see what you're saying on the Lsi's. Congrats Sumerian glad to hear you're liking them, those S3's are definitely nice cables and you did your research on that system. I bet it sounds great!
  • RamZet
    RamZet Posts: 792
    I am using MIT AVT2 interconnects on my 2ch setup. I am not using them on the CD player. I did a side by side with my CD player using Liberty Inter-flex and thought it sounded better. However my turn table, USB DAC, connection form pre amp to amp are all using the MIT.
    Maybe some day in the future I will try their speaker cables, but for now its out of my budget.
    I think the people who say you cant tell a difference are just using speakers/amps they think are good but are not or maybe their hearing isnt as good as it once was. I am not using them b/c I like to spend money or b/c they are super fancy. I am using them because they have a better sound than standard cables. I am 100% happy using Hosa and Liberty interconnects/speaker cable. But if something sounds better, im using it.
    Dot let anyone say that you wasted your money on cables.
    B&W CM9Classé Sigma
  • GlennDog
    I'm pretty sure my speaker cable journey has ended . . . with MIT
    I went up the standard food chain to thicker and thicker wire. Then, I went out on a limb and picked-up MIT AVT 2s
    Instant and significant improvement from the first song . . . I just upped-the-ante and am not looking back
    I highly recommend a listen . . .
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • ravaneli
    ravaneli Posts: 530
    Sumerian wrote: »
    another one bites the dust. Bring your cables to my house and take a seat with eyes blindfolded and try to tell them apart from my monoprice. Nobody can recognize MIT cables without eyes.
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    And..the first thread crap...usual suspects....
    tonyb Posts: 33,067
    yep.....first post in 6 months and it's to crap on someone's parade. Classy....
  • Erik Tracy
    Must be a slow day at AVS and AH
