I am going to take the plunge
Steven72555
I can't find any new speakers out here that wasn't made for home theater sound.
So.. I am going to build my own.
This is what I was looking at to put into the speaker.
Dayton Audio ST210-8 8" Series II Woofer
Aurum Cantus AC120/50CK 5" Midwoofer <this size may change
Morel CAT 408 1-1/8" Compact Soft Dome Tweeter
Dayton Audio XO3W-500/4K 3-Way Crossover 500/4,000 Hz
I figure I couldn't do any worse from what I have seen.
What speakers have you looked at? Budget?
Are these drivers and XO's based on a current known design?--Gary--
I hate to be a debbie downer but using an off the shelf formula based crossover such as that usually results in less than great results even if you use excellent drivers.The reason being is that the values used assume the drivers have perfectly flat frequency response and present a purely resistive load.Niether is the case so the result is less than ideal driver blending.A crossover must be designed specifically for the drivers used and requires accurate frequency response and impedance measurements.If you want to do DIY I would suggest looking at some of the excellent fully developed designs from the likes of Zaph Audio's, and conbributors at Parts express tech talk forum and Meniscus web sites etc..http://meniscusaudio.com/kits-c-133.html http://www.zaphaudio.com/Steven72555 wrote: »Dayton Audio XO3W-500/4K 3-Way Crossover 500/4,000 Hz
I figure I couldn't do any worse from what I have seen. -
Either you haven't looked very hard or in the wrong places as there are a vast quantity of speakers out there made for 2 channel.Location Twinsburg, Ohio
I've got family around your area, you're going to look around the Cleveland area.
In Shaker Heights, http://donbetteraudio.com/products/loudspeakers/
Another, http://www.audiovisions-online.com/homeaudio
Of course, you can always shop online at Polk's eBay store. The LSiM series are aimed at music lovers. -
Another great spot in Cleveland is Audio Craft on Carnegie Ave.
http://audiocraft.com -
Generic crossovers are the bane of the DIY world."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Not only are driver measurements from manufacturers inaccurate at times, but the cabinet they're placed in can have a huge influence in frequency response.
Start here:
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I think he was being sarcastic, facetious, what have you.Lot's of them, if you know where to look.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
No, he wasn't. Lots of nice places there.
I had a Parts Express tech guy give my cabinet plans with my choice of speakers in mind.Not only are driver measurements from manufacturers inaccurate at times, but the cabinet they're placed in can have a huge influence in frequency response.
Start here:
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible -
Again, either you haven't looked very hard or in the wrong places as there are a vast quantity of speakers out there made for 2 channel.
Where do you live? What is your stereo set up?Again, either you haven't looked very hard or in the wrong places as there are a vast quantity of speakers out there made for 2 channel.
I live outside of Cleveland, and there isn't much in the way of REAL stereo dealers out here.
Everyone is so hyped up with the home theater sound. I have looked.
I am also not going to 700+ dollars for one speaker. -
[HTML][/HTML]Steven72555 wrote: »I am also not going to 700+ dollars for one speaker.
Is that because you can't afford it, or just a matter of principle thing?
If economic then try to work out a way. If a matter of principle then that is just stupid.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
You know what..
This thread was started because I was hoping for some "constructive" hints and ideas on how I can build some speakers. After all, I am in the DIY subforum.
No its a freakin debate over what I can or cannot afford.
I shall assume there is nobody that can build speakers that wants to help me out here.
So, I will consider this thread closed and I'll go look elsewhere for some constructive help.
Thanks anyway. -
Steven72555 wrote: »Where do you live? What is your stereo set up?
I know where you live, I addressed that in post #4, but here it is again. Both are REAL stereo dealers.
Of course, you can always shop online at Polk's eBay store. The LSiM series are aimed at music lovers.I am also not going to 700+ dollars for one speaker.
I had a feeling that was the real issue. -
THAT cabinet design was given to me by one the Parts Express "Tech" guys after I told him what woofer I wanted to put in there. I even questioned him on that choice.You cabinet/dimensions appear to be for a single full range driver but then your driver/crossover compliment suggests a 3 way design.
Stuff a 3 way design into a cabinet designed for a single full range driver is going to be anything but musical. -
A pair of Magnepan MMG's could be yours for 599.00 plus shipping. They will run circles around what you are proposing.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Steven72555 wrote: »I can't find any new speakers out here that wasn't made for home theater sound.
Umm, there are a few.
Here are some:
http://www.harbeth.co.uk/uk/index.php -
That was a screwed up suggestion.mhardy6647 wrote: »
Do you own a pair?
Have you heard a pair?
Did you even check the prices on those? -
Steven72555 wrote: »That was a screwed up suggestion.
Why is that a screwed up suggestion? Your original statement was "I can't find any new speakers out here that wasn't made for home theater sound." Harbeth speakers are designed and built for musical enjoyment and not theater. He exactly addressed your questions.Steven72555 wrote: »Do you own a pair?
Yes, I believe he owns a pair; or at least a few of our members do. -
Here are two speakers from Madisound that are expertly designed, and even come with cabinets at around $400 a pair:
http://www.madisoundspeakerstore.com/preassembled-speakers/rhyme-acoustics-nuscale-216-2-way-pair/
http://www.madisoundspeakerstore.com/mtm-speaker-kits/zaph%7Caudio-za5.3-mtm-pair-with-cabinets/ -
6000 usd a pair? -
Do you own a pair?
No
Yes
Yes
They are superb. They weren't designed for home theatre.
For more affordable options, there are some very nice Pioneers now available designed by their (TAD's) Andrew Jones.
... and plenty of things in between. -
Steven72555 wrote: »6000 usd a pair?
Their P3ESR speakers start at $2300 a pair. -
Wanted to add, if you go the Maggie route, be sure the subwoofer is nice and quick. Don't go out and get a 12" $300 sub, 'cuz it ain't gonna keep up.
There is a 3 piece option for them from Magnepan that includes a sweet little sub panel...
http://www.magnepan.com/model_MMGThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Magneplanars are fine but pretty power-hungry...
Not as deep as I would like, but it is very fast and detailed, without being boomy. It will take the MMG to a level very near the 3.7's IHMO.
As far as power hungry goes, so long as the amp will tolerate a 4 ohm load, they can sound quite nice with 50 watts...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Steven72555 wrote: »You know what..
Thanks anyway.
Did you read posts 3, 7, and 9?
One poster has been published in a very popular DIY loudspeaker book, the other has won a couple of DIY competitions, both provided helpful information. Or is it you're just not hearing what you want to hear...?
Just curious, what is the difference between a speaker designed for 2 channel and one designed for HT? A well designed speaker should be able to do either proficiently."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Steven, where was this stated?I was at another "Audio" forum asking for advice, and a lot of them came off sounding like pompous ***** that figured only the best sounds had to be bought from a retailer.
http://techtalk.parts-express.com/showthread.php?239313-Building-my-own&p=1937450#post1937450"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
