I am going to take the plunge
Steven72555
Steven72555 Posts: 35
edited September 2013 in DIY, Mods & Tweaks
I can't find any new speakers out here that wasn't made for home theater sound.
So.. I am going to build my own.
This is what I was looking at to put into the speaker.
Dayton Audio ST210-8 8" Series II Woofer
Aurum Cantus AC120/50CK 5" Midwoofer <this size may change
Morel CAT 408 1-1/8" Compact Soft Dome Tweeter
Dayton Audio XO3W-500/4K 3-Way Crossover 500/4,000 Hz
I figure I couldn't do any worse from what I have seen.
Post edited by Steven72555 on
  • halo71
    halo71 Posts: 4,637
    What speakers have you looked at? Budget?
    Are these drivers and XO's based on a current known design?
    --Gary--
  • FTGV
    FTGV Posts: 3,650
    I hate to be a debbie downer but using an off the shelf formula based crossover such as that usually results in less than great results even if you use excellent drivers.The reason being is that the values used assume the drivers have perfectly flat frequency response and present a purely resistive load.Niether is the case so the result is less than ideal driver blending.A crossover must be designed specifically for the drivers used and requires accurate frequency response and impedance measurements.If you want to do DIY I would suggest looking at some of the excellent fully developed designs from the likes of Zaph Audio's, and conbributors at Parts express tech talk forum and Meniscus web sites etc..http://meniscusaudio.com/kits-c-133.html http://www.zaphaudio.com/
    F1nut Posts: 51,953
    Either you haven't looked very hard or in the wrong places as there are a vast quantity of speakers out there made for 2 channel.
    Location Twinsburg, Ohio
    I've got family around your area, you're going to look around the Cleveland area.
    In Shaker Heights, http://donbetteraudio.com/products/loudspeakers/
    Another, http://www.audiovisions-online.com/homeaudio
    Of course, you can always shop online at Polk's eBay store. The LSiM series are aimed at music lovers.
  • chumlie
    chumlie Posts: 8,658
    Another great spot in Cleveland is Audio Craft on Carnegie Ave.
    http://audiocraft.com
  • Face
    Face Posts: 14,340
    Generic crossovers are the bane of the DIY world.
  • chumlie
    DSkip wrote: »
    There's a great spot in Cleveland?
    Lot's of them, if you know where to look.
  • Face
    Face Posts: 14,340
    Not only are driver measurements from manufacturers inaccurate at times, but the cabinet they're placed in can have a huge influence in frequency response.
    Start here:
    http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
  • Nightfall
    Nightfall Posts: 10,083
    chumlie wrote: »
    I think he was being sarcastic, facetious, what have you.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,953
    No, he wasn't. Lots of nice places there.
  • Steven72555
    Face wrote: »
    Start here:
    I had a Parts Express tech guy give my cabinet plans with my choice of speakers in mind.
    F1nut Posts: 51,953
    Again, either you haven't looked very hard or in the wrong places as there are a vast quantity of speakers out there made for 2 channel.
  • Steven72555
    Where do you live? What is your stereo set up?
    I live outside of Cleveland, and there isn't much in the way of REAL stereo dealers out here.
    Everyone is so hyped up with the home theater sound. I have looked.
    I am also not going to 700+ dollars for one speaker.
  • BlueFox
    BlueFox Posts: 15,250
    [HTML][/HTML]
    Is that because you can't afford it, or just a matter of principle thing?
    If economic then try to work out a way. If a matter of principle then that is just stupid.
  • Steven72555
    You know what..
    This thread was started because I was hoping for some "constructive" hints and ideas on how I can build some speakers. After all, I am in the DIY subforum.
    No its a freakin debate over what I can or cannot afford.
    I shall assume there is nobody that can build speakers that wants to help me out here.
    So, I will consider this thread closed and I'll go look elsewhere for some constructive help.
    Thanks anyway.
    F1nut Posts: 51,953
    I know where you live, I addressed that in post #4, but here it is again. Both are REAL stereo dealers.
    I had a feeling that was the real issue.
  • zingo
    zingo Posts: 11,258
    Madisound is very good.
  • Steven72555
    ZLTFUL wrote: »
    You cabinet/dimensions appear to be for a single full range driver but then your driver/crossover compliment suggests a 3 way design.
    Stuff a 3 way design into a cabinet designed for a single full range driver is going to be anything but musical.
    THAT cabinet design was given to me by one the Parts Express "Tech" guys after I told him what woofer I wanted to put in there. I even questioned him on that choice.
    nooshinjohn Posts: 25,985
    A pair of Magnepan MMG's could be yours for 599.00 plus shipping. They will run circles around what you are proposing.
    mhardy6647 Posts: 35,201
    Umm, there are a few.
    Here are some:
    http://www.harbeth.co.uk/uk/index.php
  • Steven72555
    Here are some:
    That was a screwed up suggestion.
    Do you own a pair?
    Have you heard a pair?
    Did you even check the prices on those?
  • zingo
    zingo Posts: 11,258
    Why is that a screwed up suggestion? Your original statement was "I can't find any new speakers out here that wasn't made for home theater sound." Harbeth speakers are designed and built for musical enjoyment and not theater. He exactly addressed your questions.
    Do you own a pair?
    Yes, I believe he owns a pair; or at least a few of our members do.
  • Steven72555
    zingo wrote: »
    6000 usd a pair?
    Do you own a pair?
    No
    Yes
    Yes
    They are superb. They weren't designed for home theatre.
    For more affordable options, there are some very nice Pioneers now available designed by their (TAD's) Andrew Jones.
    ... and plenty of things in between.
  • zingo
    zingo Posts: 11,258
    6000 usd a pair?
    Their P3ESR speakers start at $2300 a pair.
    DSkip wrote: »
    Wanted to add, if you go the Maggie route, be sure the subwoofer is nice and quick. Don't go out and get a 12" $300 sub, 'cuz it ain't gonna keep up.
    There is a 3 piece option for them from Magnepan that includes a sweet little sub panel...
    http://www.magnepan.com/model_MMG
    Magneplanars are fine but pretty power-hungry...
    Not as deep as I would like, but it is very fast and detailed, without being boomy. It will take the MMG to a level very near the 3.7's IHMO.
    As far as power hungry goes, so long as the amp will tolerate a 4 ohm load, they can sound quite nice with 50 watts...
  • Face
    Face Posts: 14,340
    You know what..
    Thanks anyway.
    Did you read posts 3, 7, and 9?
    One poster has been published in a very popular DIY loudspeaker book, the other has won a couple of DIY competitions, both provided helpful information. Or is it you're just not hearing what you want to hear...?
    Just curious, what is the difference between a speaker designed for 2 channel and one designed for HT? A well designed speaker should be able to do either proficiently.
  • Face
    Face Posts: 14,340
    Steven, where was this stated?
    I was at another "Audio" forum asking for advice, and a lot of them came off sounding like pompous ***** that figured only the best sounds had to be bought from a retailer.
    http://techtalk.parts-express.com/showthread.php?239313-Building-my-own&p=1937450#post1937450
