subwoofer sinclair?
Parachoute
Parachoute Posts: 88
edited September 2013 in Speakers
Hi guys,
I want to upgrade from my old psw10 and am wondering if this might be an improvement.
http://quebec.kijiji.ca/c-acheter-et-vendre-equipement-electronique-Subwoofer-Sinclair-W0QQAdIdZ521026115
any thoughts?
Thanks for your help.
Post edited by Parachoute on
  • Inspector 24
    Inspector 24 Posts: 1,308
    Probably, having a passive radiator is usually a beneficial thing. What are the specs?
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Parachoute
    • 10” active polyCel driver
    • Dual 10” Passive Depth Radiators
    • An integrated 250 watt amplifier
    • A frequency response of 30Hz-150Hz
    • Measures 15” x 15” x 16 1/8
    mhardy6647 Posts: 34,916
    compared to what...?
    I mean, there's nothing wrong with PRs but they're not magic, either.
  • codyc1ark
    codyc1ark Posts: 2,533
    I would say yes, it looks to be an upgrade from a PSW10, most subs are. :smile: However, with only 30hz spec, I would pass. What would be your budget for an upgrade, maybe we can help a bit. Are you using this for HT or music?
  • Parachoute
    budget around 150-300$.
    I use the sub only for HT. I have: Rti10, Csi3, FSi3 and...PSW10!
    I'm also looking to upgrade the CSi3 to CSi5. I'm telling just in case someone would like to get rid of one of those...;).
    I live in Canada, so shipping/shipping cost may be a problem.
  • Inspector 24
    [smartass]
    SVS PB13? But but not the ultra, it's too good.
    Wonder what SDA fans would say about that :biggrin:
    [/smartass]
    On a serious note google found me this. Seems pretty comprehensive.
    http://www.aespeakers.com/PRFAQ.php
    Up
    Down
  • codyc1ark
    Parachoute wrote: »
    http://www.hsuresearch.com/products/stf-2.html
    If you can wait and save a bit, there are some killer options in the ~500 range. Good luck!
