PSW110 Woes
dres312
dres312 Posts: 6
edited July 2015 in Troubleshooting
Hey all,
I don't know what could have caused this, but my sub isn't working. I suspect it had something to do with moving it from my house to the house I'm living in now (I'm in college). Before the move, it was working fine, but once I arrived at the house and hooked everything up, the sub just won't turn on upon flipping the power switch. I'm wondering if it is possible that the fuse blew?
Or maybe something is shorted? A problem I started to notice happening before this incident is that when touching/turning the volume knob, sometimes the volume would spike, but that was very intermittent.
Also, I brought my sub from Amazon I'm pretty sure, not through Amazon. However, I don't have the receipt anymore and Amazon only holds your order history from January of 2012. Knowing this, and people having to pay $**** to get their audio equipment fixed (usually in the same situation as me), is it worth it to just open up the back or take out the woofer and do a little investigation by myself since I'm a pretty technical guy, or call customer service which usually ends up causes more frustration than it is worth?
  • boston1450
    boston1450 Posts: 7,758
    edited August 2013
    You kinda answered it in your own words. Id crack it open and take a look. Then youll have more info to go on. Good luck & hope its a easy fix---- i also have problems keeping paperwork. My wife prints out every purchase i do on internet. It has helped alot. GL
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited August 2013
    Hello dres312,
    In all likelihood there's a problem with the amplifier's volume control and a transient spike probably blew the AC fuse. The bass amplifier will have to be removed and sent to Polk's west coast service center. The amplifier comes with a three year warranty and all you'll have to do it provide a proof of purchase to Polk. Did you register the unit on Polk's web site?
    Contact Polk's CS department at: 1-800-377-7655 or via email to: polkcs@polkaudio.com.
    Regards, Ken
  • dres312
    dres312 Posts: 6
    edited September 2013
    Just got back in country. Yes, I registered it a few days after I bought it. I'll make sure to call them tomorrow.
  • [Deleted User]
    Perfect, it's always best to register your purchases. Polk will be able to help.
  • MJSid
    MJSid Posts: 1
    My 0-180 phase switch broke and fell out. Now the sub won't make a sound. It turns on, senses the input but does not move the woofer cone. I looked at the board and the fuse is not blown. Any ideas.
  • [Deleted User]
    Hello,
    Welcome to Polk's forum. The bass amplifier is going to need either replaced or repaired. Best to contact Polk's CS department either at 1-800-377-7655 or email to polkcs@polkaudio.com
    Regards, Ken
