Adcom GFA 5500 Help
oleon621
oleon621 Posts: 178
edited September 2013 in Electronics
I'm an amp newbie and I'm looking for advice on how to set it up. Any help would be appreciated.Ex. Large or small? What crossover to use? How should this be connected? Do i Bi wire? Would some good old monoprice cables do the job or should I get something from the likes of Blue Jeans cable or audioquest?
Any advice or tips is welcomed!
Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000
Post edited by oleon621 on
  • ratster
    ratster Posts: 324
    Their is no large or small settings and no crossover. Hook up to your pre outs and mono price is just fine,and bi wire if you want to.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • Nightfall
    Nightfall Posts: 10,084
    Bi-amping on the same amp is worthless from what I've read.
    Most around here are against Monoprice and will recommend Blue Jeans at a minimum. Will Monoprice cables/wires work? Of course.
    Connect the Adcom to the preouts on your Yamaha with RCA IC's.
    As far as large/small goes, just run YPAO again after getting everything hooked up and let the Yamaha figure it out. I think the standard, however, is to set all your speakers to small and set the crossover point to 80Hz on all your speakers. Turn the crossover point on your sub as high as it goes before running YPAO.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • oleon621
    oleon621 Posts: 178
    How about bi wiring? Is that worth the effort? I ran YPAO and it set the front stage to large which I changed to small and then set the crossovers on the mains to 40hz and the center channel to 80hz.
    Center- CSI5,
  • Boonaroo
    Boonaroo Posts: 57
    If you have the extra cable, try bi-wiring.
  • Glen B
    Glen B Posts: 269
    Nightfall wrote: »
    You should quote from direct experience, not what some others have said.
  • Nightfall
    Glen B wrote: »
    I don't understand what is wrong with passing on information I have read on these forums over and over as long as I specify that it's hearsay?
    afterburnt wrote: »
    tonyb Posts: 33,072
    Nightfall wrote: »
    Nothing, don't sweat it man. You clearly stated it was from " what you have read".
    That said, and before this escalates out of proportion, Glen was eluding to the fact that you can't believe everything you read....including here. Heaven knows, some bad advice has been doled out here too but that's neither here nor there. Glen also eluded to "speaking from experience" is the best which it is but in no way assumes your opinion isn't valid, which it also is.
    BTW, the OP is asking about bi- wire/amping from an amp, not a receiver. At least that's my take on it since he was asking about the Adcom 5500.
  • oleon621
    oleon621 Posts: 178
    Just a quick update fellas. I did not bi- wire/amp. I did get some new IC's from Audioquest and I couldn't be happier with the amp. Thanks!
    Center- CSI5,
