Which speaker would be the best for Rear and Rear Surround
Here are my choices. If you want to see where they go click here:
http://www.avsforum.com/t/1488741/argyl-theater-concept-first-time-builder-in-lees-summit-mo
From a sound quality perspective can you guys help me out. Maybe rank them or give me advice on how they would sound. The only ones I sort of have experience with is the TC-80i/ I am using 4 in ceiling now for my family room theater. I love the way it sounds but I want the Home theater to be the best.
Thanks,
Chip
- Fxi-a6 - Would be on wall but sticks out at least 8 5/8" into the theater space
- 265-RT - Would be in wall with a painted grill or in a fake column
- 80F/X-RT - Would be in wall with a painted grill or in a fake column
- TC-80i - Would be in ceiling
Thanks,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Monster HTS 3600
Post edited by chiptouz on
I don't have any experiance with the others but the A6's were designed for this application and they work very well.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
All options work and work well. I like In walls for surrounds as they make for a clean Install. It's pure myth that In walls or In ceilings don't sound good.
Dipolar and Bipolar speakers are a solution speaker to a age old problem. They are not designed for Dolby Digital or DTS and beyond. They are designed for Dolby pro logic to give a larger sound field out of mono channels. yes you can use them in todays setups but nothing sounds better then direct firing surround speakers especially when placement is correct.
I prefer In wall over In ceiling depending on placement but I have done many In ceiling systems in theater rooms that sounded amazing.Dan
My experience is limited on your list.
I've only used Monitors; 30, 40 and 70 in the "side" surround position as far as bookshelves and towers go. Once I put the FXiA6 in place, all else paled in comparison. -
I'm using FxiA4, is amazing surround...|Front: Polk RtiA7|Center: Polk CsiA4|Side: Polk FxiA4|Back: Wharfedale WH2|Sub: Wharfedale SW150|
|AVR: Yamaha RX A1010|BDP: DENON UD1611|Int. Amp: Rotel RA1520
|TV: LG 3D 55LM6700|Console: PS3 Slim 120Gb|
