Which speaker would be the best for Rear and Rear Surround
chiptouz
chiptouz Posts: 152
edited September 2013 in Speakers
Here are my choices. If you want to see where they go click here:
http://www.avsforum.com/t/1488741/argyl-theater-concept-first-time-builder-in-lees-summit-mo
  1. Fxi-a6 - Would be on wall but sticks out at least 8 5/8" into the theater space
  2. 265-RT - Would be in wall with a painted grill or in a fake column
  3. 80F/X-RT - Would be in wall with a painted grill or in a fake column
  4. TC-80i - Would be in ceiling
From a sound quality perspective can you guys help me out. Maybe rank them or give me advice on how they would sound. The only ones I sort of have experience with is the TC-80i/ I am using 4 in ceiling now for my family room theater. I love the way it sounds but I want the Home theater to be the best.
Thanks,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Post edited by chiptouz on
  • zane77
    zane77 Posts: 1,696
    I don't have any experiance with the others but the A6's were designed for this application and they work very well.
    Two Channel
  • mantis
    mantis Posts: 17,563
    All options work and work well. I like In walls for surrounds as they make for a clean Install. It's pure myth that In walls or In ceilings don't sound good.
    Dipolar and Bipolar speakers are a solution speaker to a age old problem. They are not designed for Dolby Digital or DTS and beyond. They are designed for Dolby pro logic to give a larger sound field out of mono channels. yes you can use them in todays setups but nothing sounds better then direct firing surround speakers especially when placement is correct.
    I prefer In wall over In ceiling depending on placement but I have done many In ceiling systems in theater rooms that sounded amazing.
    Dan
  • Geoff4rfc
    Geoff4rfc Posts: 2,962
    My experience is limited on your list.
    I've only used Monitors; 30, 40 and 70 in the "side" surround position as far as bookshelves and towers go. Once I put the FXiA6 in place, all else paled in comparison.
  • gameover
    gameover Posts: 5
    I'm using FxiA4, is amazing surround...
    |Front: Polk RtiA7|Center: Polk CsiA4|Side: Polk FxiA4|Back: Wharfedale WH2|Sub: Wharfedale SW150|
    |AVR: Yamaha RX A1010|BDP: DENON UD1611|Int. Amp: Rotel RA1520
    |TV: LG 3D 55LM6700|Console: PS3 Slim 120Gb|
