a stupid ohms question
Bacchus
Bacchus Posts: 20
edited September 2013 in Vintage Speakers
ok I think I have been thinking of the effect of two sets of speakers on ohms of resistance in reverse... I was thinking two sets of speakers hooked up one set of 4 ohm speakers hooked up to "A" L&R and a second set connected to "B" L&R would create an 8 ohm resistance..... I may be wrong here....
would this set up create an 8 ohm or a two ohm load to the amp?
Post edited by Bacchus on
  • BlueFox
    BlueFox Posts: 15,250
    Resistors in series are additive; 4 ohm + 4 ohm = 8 ohms. Resistors in parallel add inversely, so 1/4 + 1/4 = 2/4 = 1/2 = 2 ohms.
    Without seeing the schematic of the source, I would err on the conservative side, and assume the A and B connections are wired in parallel.
    http://physics.bu.edu/py106/notes/Circuits.html
    mhardy6647 Posts: 35,397
    Actually since loudspeakers are reactive devices and you're interested in using them with an AC waveform (music!), technically the load is impedance not resistance. Impedance is the AC analog of DC resistance, but it is made up of three components - DC resistance, capacitive reactance and inductive reactance. The latter two properties vary with frequency, so impedance isn't constant - it varies with frequency (and that's where all the fun begins in matching amplifiers with their loudspeaker loads).
    Fortunately, though, impedance, like resistance, obeys Ohm's Law! :-)
  • Bacchus
    Bacchus Posts: 20
    so If I hooked up two 4 ohm sda's in series the amp would see a 8 ohm load...?
    Two nominal 4 ohm impedance speakers in series does represent a nominal 8 ohm load. It's not generally the best way, sonically speaking, to hook up loudspeakers, as each will "feel" the other's effects, electrically, which is quite likely to have audible consequences... and they won't likely be favorable consequences.
    In the specific case of SDAs - given their unique design parameters - I do not feel qualified to comment on them. I rather doubt Polk intended pairs of them to be connected in series... and it might even be detrimental.
  • rpf65
    rpf65 Posts: 2,127
    In your particular instance, you would be creating a 2 ohm load, mathematically that is.
    Recommend that you never hook up speakers this way, really bad things can happen, very few if any will be good.
    If you want to run 4 speakers, get a pre/AVR/receiver with t least 4 speaker out puts.
  • Schurkey
    Schurkey Posts: 2,122
    rpf65 wrote: »
    2 pair of 4-ohm speakers connected in series = 8 ohm load
    2 pair of 4-ohm speakers connected in parallel = 2 ohm load.
    rpf65 wrote: »
    Connected in series = poor sonics
    Connected in parallel = high current demand from the amplifier, most of which will fry trying to drive a 2-ohm nominal load. Very few amps will be comfortable with that much current draw. Fewer still will sound good driving that load.
    rpf65 wrote: »
    Number of "out puts" doesn't matter. What matters is the way those outputs are wired to the amplifier(s) that provide the power. A stereo amplifier (two amplifier channels) driving four, four-ohm speakers is likely to be in trouble. A four-amplifier "multichannel" amp may--or may not--be fine with four speakers each a four-ohm load. A cheap multichannel amp will probably not support four-ohm nominal loads. A good multichannel amp will be fine.
    You guys are splitting hairs here, what the OP wants to do with what he has on hand simply won't cut the mustard.
    Depending on what he wants to spend, his options vary, but as he sits with an old receiver and 4 SDA's, he has none at the moment.
  • Bacchus
    Bacchus Posts: 20
    Sounds like the answer is preamp and two separate power amps then....
    tonyb wrote: »
    True, but I have this deep seated bias that "forewarned is forearmed" and so I like to at least endeavor, in my ham-fisted way, to illustrate why we would say "Don't connect your speakers like that!".
  • TennMan
    TennMan Posts: 1,266
    I will offer what I think is one good reason not to use four speakers if your goal is to get the SDA sound from 2 channels.
    The SDA effect is all about timing of when the sound waves reach our ears from the stereo drivers and the dimensional drivers. It is hard enough to get speakers set in the right position in the room (not to mention the ill effects room acoustics can present) to get the timing right with just two speakers. I found that adding another set of SDA speakers in the rear throws off the timing and degrades the SDA sound that you are trying to achieve.
    I own a pair of 2Bs that I use in the front and a pair of CRS+ speakers that I've tried in the rear. I didn't try all four speakers with a 2 channel amp. I used a receiver made for multichannel operation with it set to the "pure direct" setting so it didn't add any surround sound effects. I didn't like the results for 2 channel listening. It was just OK for movies. For me 2 SDAs in the front is the way to go for 2 channel stereo.
    In my opinion it is better to use the right tool for the job. Try two of the SDAs in the front for a while and see if you like them. Take the time to get them setup properly and then take the time to get to know them. You might find you like what you hear. If you try the SDAs for a while and discover you want true surround sound then buy a receiver and speakers designed for multichannel operation.
  • westmassguy
    westmassguy Posts: 6,850
    TennMan wrote: »
    SDAs can serve double duty quite well. My 2As are integrated into my Home Theater. All the other speakers are either custom, or off-the-shelf vintage Monitors, for timbre matching. I had my CRS+s as rear/surrounds when my system was 5.1, but they have been retired from those duties, now that the other speakers are in place. Two channel is just a matter of switching my AVR/Pre-amp to Pure Direct.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • aliraza2925
    I think you want to get 8 ohm resistance by two 4 ohm speaker. It is possible only by adding them in series arrangement. like Rt = 4+4 = 8 ohm. So total resistance will be equal to 8 ohm by adding them.
    For more information, please visit this link
    http://electronicslab4u.com/series-circuit-resistors-in-series/
    I think he may have figured it out....7 years ago.
  • aliraza2925
    Ohh yeah...
    Sorry.. I didn't observe.
    pitdogg2 Posts: 27,581
    I've never understood folks who fly in to comment on super old threads
    Lol
  • skrol
    skrol Posts: 3,481
    Lol
    Imagine the OP was siting there wringing his hands, waiting for an answer for 7 years... Finally!
    Stan
    Main 2ch:
    HT:
    Other stuff:
    skrol wrote: »
    Lol
    Patience is a virtue. B)
