RTA 12C Tweeters
Faustin
Faustin Posts: 1,151
edited August 2013 in Vintage Speakers
I am looking for advise as to what tweeter people would use in RTA 12C's with rebuilt crossovers.
SL 1000
SL 2000
Peerless
or RDO 194's
Have all in stock.
Post edited by Faustin on
    pitdogg2 Posts: 27,312
    edited August 2013
    RDO194 without a doubt....
  • Mystery
    Mystery Posts: 2,546
    edited August 2013
    You should be able to jump to RDO-198 with some capacitor value change.
    From 12uF to 13.5 uf and 1 ohm resistor from what I searched.
  • Nightfall
    Nightfall Posts: 10,083
    edited August 2013
    The newer RDO's are better than peerless? I haven't heard them and I suppose it's objectional.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • westmassguy
    westmassguy Posts: 6,850
    edited August 2013
    Bruce, listen to the Peerless for a while, then switch in the 194s. See which you prefer. You need to wait for the caps to burn in completely too, before you make a final decision.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • drumminman
    drumminman Posts: 3,396
    edited August 2013
    From info gathered here in the board it should be the RD0-194, and then the Peerless. However, I still have my original SL1000's in. I'm usually very sensitive to harshness, etchiness in the highs and with mine I just don't hear it. The Sonicaps/Mills probably have something to do with that.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2013
    He 194's are very nice much better than the sl2000's once switched you wont be sorry.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Faustin
    edited August 2013
    Hmm. Interesting to here everyones opinions.... and greatly appreciated. Even when I asked the people at Polk I seemed to get conflicting info. Asked what tweeter was originally in them and was told the SL2000. When I bought them there were SL 1000 in them. Polk said SL 1000 and Peerless would not fit. Well, SL1000 came out and currently I have Peerless in them. I will let them play for a couple of weeks and then swap them around to see what I think. In a lot of cases it seems to be a persons individual taste and how they "hear" things.
  • boston1450
    boston1450 Posts: 7,758
    edited August 2013
    100% correct You hit it on the button
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
