Speaker gasket tape
MillerLiteScott
MillerLiteScott Posts: 2,564
edited September 2013 in DIY, Mods & Tweaks
What size gasket tape should I order 3/8" or 1/2"?
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited November 2007
    What speaker are you trying to apply it to?
  • MillerLiteScott
    2B's & RTA 11t's
  • avguytx
    avguytx Posts: 1,628
    I just ordered a roll of 3/8" from PE. I thought about getting the 1/2" for the heck of it but didn't. The outside edge of the MW speakers will work with the 3/8" stuff no problem.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • MillerLiteScott
    I thought 3/8's was enough and 1/2" would be a little big.
  • hearingimpared
    hearingimpared Posts: 21,136
    Both, I've used both along with speaker sealer. I got mine from parts express.
    F1nut Posts: 51,794
    Scott, you don't need that stuff. Believe it or not, the original gaskets do a fine job of sealing.
  • hearingimpared
    :p:p:p:p:p:p:p:p:p:p:D
  • MillerLiteScott
    My PR gaskets were as thin as a piece of paper and had the sealing characteristics of a piece of paper.
  • hearingimpared
    I used a double layer of speaker sealer for my PRs. Those suckers wll never have an air leak. I also used the speaker sealer to close and seal of the bursted seam from the bottom brace to the bottom pedestal right front side of my cabinet. While I pulled the seam apart my wife shoved in the speaker sealer into the seam and then when I released it the seam was sealed shut.
    I love that speaker sealer.
    F1nut Posts: 51,794
    Yeah, that's the way they are suppose to be. I've removed my PR's a whole lot of times, the gaskets are paper thin, no air leaks, tons of bass.
    Not to mention the risk of stripping out the screw holes when using a thick gasket.
  • MillerLiteScott
    I Dynamated the PR's and mid drivers in all my speakers tonight. So I made sure the gaskets weres placed properly when I put everything back together.
    I will give them a listen tomorrow. My wife and I watching a movie right now.
  • hearingimpared
    Just as an FYI, the speaker sealer flattens out very, very thin and doesn't stress the screw holes like the gasket does. It just spreads and seals. Like I said above, I love that stuff.
    Also, I have reused the original speaker gasket and found that works well.
  • hearingimpared
    I noticed that the mids sounded a bit creamier when I did mine. Also the imaging was more precise and stable.
    F1nut Posts: 51,794
    Ah, they have something other than that thick sticky stuff, eh?
  • MillerLiteScott
    Joe where did you get the speaker sealer form?
    Parts Express?
  • hearingimpared
    Parts Express?
    Yes sir!
  • HolkusPolkus1
    HolkusPolkus1 Posts: 12
    edited August 2013
    Can I just ask a question or two. I just finished making two really nice gaskets for my rear Polk Audio Speakers - I retrofitted db650's to a car that is supposed to use db651s. So anyway, I then ground down some screws to get better clearance from the rubber ring on the outside of the speakers so that's done. And I have the connectors. Now when I put the gasket in - should I put the yellow spongy thing in below the gasket or above? And should I use some Loctite Silicone Sealer from Parts Express and how should I use it? Should I more or less caulk a little to keep sound from leaking. I also wanted to put a little wood glue just on the inside edge of the gasket just to make sure it doesn't fray. Anyway, just wondering what you meant by speaker sealer - meaning is it that silicone sold by Parts Express? Any help appreciated. If I don't get an answer, I'll just wing it. I have the yellow spongy thing from Polk, I just don't show it in the pictures. I made the gasket to raise up the db650 since it's a bit too big. I'm just trying to get this done in a hurry. I know I should build a custom speaker cabinet - I can do that when I have the time. This should do for now. But if you want to criticize me, that's ok - I don't care.
  • jon s
    jon s Posts: 905
    edited August 2013
    What about using high density weather stripping? Would that work? Tightening the bolts should compress and seal the speakers, no?
  • HolkusPolkus1
    edited August 2013
    jon s wrote: »
    Yes, tightening the bolts is sufficient since my gasket is pretty much an almost perfect fit - I was just wondering if
    people get in the habit of drawing a bead of silicone around the edge just to give a little more seal and holding power - against vibrations, water degradation, whatever might shorten the lifespan. I just wanted to survey the crowd a little and see what they do - this is my first car speaker install ever - I'm a little bit novicey here. By the way, I will put a touch of epoxy on the threads to combat the screw from spinning. My initial tests of the screws are that they are quite tight even though the diameter is less than the holes but I think a little loctite or epoxy will do the screws good - maybe just loctite - see how that goes. I don't really mind if I have to pull the door panels 6 months from now.
    Here's something though - do I have the right philosophy to begin with? My idea is to couple the speaker through Home Depot's HB fiberboard - it isn't like dense wood - it's "weakish" sort of coupling. I don't want the whole car vibrating with my speakers. Would you agree or do people want to transmit vibrations to the door panel? I want my car itself to act as the speaker box more or less. Just need some "yes, you're in the right direction", or "no way man".
    So the high-density weather-stripping will tend to "reflect" acoustical energy forwards towards the listener? I guess I can get this at Home Depot?
    Thanks.
    pitdogg2 Posts: 27,069
    edited August 2013
    never use silicone
  • HolkusPolkus1
    edited August 2013
    never use silicone
    Yeah, we want something that dries firm by kind of soft and doesn't get flaky.
    Some guys recommend either of the following:
    Parts Express black sealant (#269-300)
    or:
    A Home Depot choice would be gray electrical putty (see attached). It is relatively inexpensive and goes a long way. You will sometimes see this stuff sold on Ebay as "AR sealant" for much more money.
    I'll try one of the above. I could probably use Gorilla Glue but I'm afraid to - I have never used it even though I have some.
    edited August 2013
    or:
    Or you could of used rope caulk (mortite) Silicone gives off an acid as it cures not good for speaker parts or wires.
    Gorilla is another no no it will swell into something it should not be on....
  • HolkusPolkus1
    edited August 2013
    or:
    The above was discontinued - now it's
    Part #: 260-400 Weight: 1.80 lbs.
  • HolkusPolkus1
    edited August 2013
    I had already ordered two products from Parts Express:
    Speaker Gasketing Tape 1/8" x 3/8" x 50 ft. Roll
    Part Number: 260-540
    1 $7.90 $7.90
    12" Speaker Sealing Caulk Box of 72 Pcs.
    Part Number: 260-400
    1 $9.50 $9.50
    UPS Ground
    $13.05
    Order Total: $30.45
    But for my front speakers, I will go to Home Depot and pick up some of the grey weather-stripping caulk (mortite) as I would like to see both products in action. Thanks for the idea to use the mortite.
    And thanks for the comment on the acid - I was wondering what the problem was with silicone.
    edited August 2013
    duplicate post
    edited August 2013
    1 $9.50 $9.50
    I'd just stick with the above. you will have more work with mortite to get to the right thickness
    nooshinjohn Posts: 25,932
    edited August 2013
    1 $7.90 $7.90
    1 $9.50 $9.50
    UPS Ground
    $13.05
    Order Total: $30.45
    Armacell works better and is 8 bucks or less
  • HolkusPolkus1
    edited August 2013
    I put the left-rear speaker in today and it sounds really good. I cranked it up with Jimi Hendrix Ultimate Experience and Concert for Bangladesh. All Along the Watchtower was really crisp - really sharp-sounding - this is exactly what I wanted. I am impressed with the sounds. So tomorrow I'll do the other rear.
    Couple comments:
    1) 1 1/2" screws are long enough as expected. Any longer and they might protrude inside the door panel and scratch someone looking for a dropped part or tool in there. Best not to use 1 3/4"ers.
    I used a 3/16" gasket so the 1 1/2"s should work for 3/16" or 1/4" gaskets. Logically, even
    1 1/4" screws SHOULD work. I'll have to feel back there with my fingers tomorrow but I don't
    think I made it by much.
    2) The ground-down heads worked really nicely - they just missed the rubber ring.
    3) The connector from ebay - www.spiralinstallations.com made it easy. Here's a nice website to give
    you the color-coding, assuming you don't want phased speakers.
    http://www.carstereo.com/help/carwires.cfm
    4) When I increase the volume, it really starts to tickle me on the carseat - so plenty of power coming from that speaker. I sat and watched the speaker going in and out - I hadn't really
    done that much in my life.
    I have only put 1 of 4 in. They are much better than the factory originals which were like 15Watters and had simple paper cones.
    The new Polk Audio db650s are like 6 - 60 Watts, 180 Watts peak. The Pioneer DEH-3800MP puts out like 50 Watts per channel or something like that.
    These speakers are vintage and are not sold anymore but they are liquid-cooled and sound real nice for the price.
    I will have to redo the job when my putties come in.
  • HolkusPolkus1
    edited August 2013
    As a number 5 to the above:
    5) I DID have to drill out the holes of the speaker a smidgen so that the #10 wood screw's barrel would fit inside the hole.
    I misplaced my caliper, otherwise I would post the drill-bit size - it's whatever drill bit matches the size of the barrel
    on a #10 wood-screw.
  • HolkusPolkus1
    edited August 2013
    In #5 above, I used a 3/16" drill which is .1875". Any size drill between approximately .179" and .1875" should do as the
    screw's barrel tapers out from about .179" roughly near the middle to .1875" (3/16") at the very top of the barrel (just under the head of the screw).
