RTA 12C Tweeters
Faustin
I am looking for advise as to what tweeter people would use in RTA 12C's with rebuilt crossovers.
SL 1000
SL 2000
Peerless
or RDO 194's
Have all in stock.
SL 1000
SL 2000
Peerless
or RDO 194's
Have all in stock.
Post edited by Faustin on
RDO194 without a doubt....
You should be able to jump to RDO-198 with some capacitor value change.
From 12uF to 13.5 uf and 1 ohm resistor from what I searched.
The newer RDO's are better than peerless? I haven't heard them and I suppose it's objectional.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Bruce, listen to the Peerless for a while, then switch in the 194s. See which you prefer. You need to wait for the caps to burn in completely too, before you make a final decision.Home Theater/2 Channel:
dhsspeakerservice.com/ -
From info gathered here in the board it should be the RD0-194, and then the Peerless. However, I still have my original SL1000's in. I'm usually very sensitive to harshness, etchiness in the highs and with mine I just don't hear it. The Sonicaps/Mills probably have something to do with that."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
He 194's are very nice much better than the sl2000's once switched you wont be sorry.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Hmm. Interesting to here everyones opinions.... and greatly appreciated. Even when I asked the people at Polk I seemed to get conflicting info. Asked what tweeter was originally in them and was told the SL2000. When I bought them there were SL 1000 in them. Polk said SL 1000 and Peerless would not fit. Well, SL1000 came out and currently I have Peerless in them. I will let them play for a couple of weeks and then swap them around to see what I think. In a lot of cases it seems to be a persons individual taste and how they "hear" things.
100% correct You hit it on the buttonRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
