Does the length between paired speakers matter?
Sumerian
Sumerian Posts: 490
Will there be any effect on the SQ if the wire length from AVR/Amp to Left front is different to Right front?
My AVR/Amp is close to left speaker planning to get 1 meter (4.92 feet) MIT Shotgun S3 for Left and 8 Feet MIT Shotgun S3 for Right will this have any effect?
Or is it suggested to keep the lengths same?
Post edited by Sumerian on
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2013
    If you rearrange your gear you might find the short cable to be a problem. There will not be any audible difference in sound with only a 4' difference in cables. When you setup your AVR it uses the length of the distance between the speaker and your seat. It doesn't care about the cable length.
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    BlueFox wrote: »
    thanks for the reply
    F1nut Posts: 52,164
    edited August 2013
    This is a non-issue because the shortest speaker cable lenght MIT sells is 8 feet.
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    Joe also have 1.5 meter cables
    F1nut Posts: 52,164
    edited August 2013
    Speaker cables???
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    Speaker cables???
    My bad... they are RCAs you are correct minumum is 8 feet .
    edited August 2013
    Ok, color me stupid today, why on earth would you need an 8 ft RCA cable ? The rca's go from receiver to amp, no way those are 8 ft. apart.
    Speaker cables should be bought in equal lengths, with a tad extra just in case you have to move gear around, rearrange the room.
  • WilliamM2
    WilliamM2 Posts: 4,809
    edited August 2013
    tonyb wrote: »
    My rack is 5 feet tall, I need 6 feet to go from the receiver on top shelf to the amp on the bottom shelf. The need for 8 ft isn't really that hard to imagine. But I believe he was talking about speaker wires.
    Why should they be equal lengths? My equipment is in the back corner of the room, they aren't equal lengths. Speaker wire should be in the wall, not on the floor like most amateur installs.
    edited August 2013
    WilliamM2 wrote: »
    While your situation may be unique, definitely not the norm. Also, speaker wire in the wall ? Also not the norm, nice to do, but not the norm. Usually speakers are set equal distances from center, and people usually re-arrange rooms over time too so hence my thoughts. Not written in stone, but this is usually why when you buy speaker cables, they come in equal lengths.
    F1nut Posts: 52,164
    edited August 2013
    Well, for one thing in the case of better cable, that's the way they come.
    I've never seen a serious 2 channel rig with in wall speaker cable.
    edited August 2013
    Not to mention in-wall speaker cables makes it a tad hard to try new cables every so often.
    treitz3 Posts: 20,208
    edited August 2013
    In wall speaker cables add more unnecessary connections. A big audiophile no-no.
  • BlueFox
    edited August 2013
    WilliamM2 wrote: »
    Apparently, you associate with serious amateurs. :lol:
    F1nut Posts: 52,164
    edited August 2013
    BlueFox wrote: »
    After all these years.....who knew!
  • WilliamM2
    edited August 2013
    tonyb wrote: »
    I don't believe in wasting time listening to cables. I listen to music.
  • WilliamM2
    edited August 2013
    treitz3 wrote: »
    No extra connections, I use these in the wall behind the rack, and a single hole behind each speaker:
    http://www.amazon.com/DataComm-45-0002-WH-2-Gang-Recessed-Voltage/dp/B001C4BEOY/ref=sr_1_5?ie=UTF8&qid=1377660802&sr=8-5&keywords=wall+plates
    F1nut Posts: 52,164
    edited August 2013
    WilliamM2, I've got to hand it to you, you're always good for a chuckle.
  • WilliamM2
    edited August 2013
    I'm sure I get just as much entertainment from your posts, so it all evens out.
    F1nut Posts: 52,164
    edited August 2013
    There you go, making me laugh again.
  • BlueFox
    edited August 2013
    WilliamM2 wrote: »
    To bad you can't hear it. :rolleyes:
    edited August 2013
    WilliamM2 wrote: »
    ....and you can't listen to music without cables. Also lends itself to.....you can't listen to better music if you never try better cables/gear.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited August 2013
    F-1 I know exactly what William m2 is talking about .I've pre wired hundreds of houses for both alarm and music.and all are home runs w/ no splices anywhere. It's up to the customer as to what wire he/she wants to use w/ our instruction and how long the runs were.We usually used Carol 12gu in wall class 2 w/ either new work boxes to except ready made plates for banana plugs or just a 6/8' tail of wire coming out of lets say a cable plate w/ the f-connector removed. At the amp end all would be marked w/ tape or #tags and either go to a speaker selector3gang plate or to the amp it'self depending on how big the system was.If not planned right then yes YSOOL,so that's why you have a sit down between electrician,alarm dude, and designer to get all the stars aligned.
    F1nut Posts: 52,164
    edited August 2013
    Lew, he's a cable/gear naysayer, that's all.
  • WilliamM2
    edited August 2013
    BlueFox wrote: »
    Too bad you never learned to spell.
  • WilliamM2
    edited August 2013
    Sounds like a serious lack of experience.
    edited August 2013
    WilliamM2 wrote: »
    Just the opposite William. You'll find just by looking on other forums, viewing pics, the majority of good 2 channel systems don't use in-wall cables.
    Another reason why is because in-walls will require additional footage, and when we are talking better more expensive cable, it makes no sense.
    Maybe your satisfied with your cables and never intend to use anything else, which is fine and dandy....for you.
    But calling the ones who don't use in-walls "amateur" ,LOL well that's just amateur in itself.
  • BlueFox
    edited August 2013
    DSkip wrote: »
    I really hope Mr. M2 is talking about HT installs and not a 2 channel system.
    He is just another troll who periodically surfaces, and tries to stir the pot. Personally, I find these clowns amusing, even if they are frowned upon. Why they revel in ignorance is subject matter for countless hours of discussion.
    F1nut Posts: 52,164
    edited August 2013
    WilliamM2 wrote: »
    Please don't attempt to pass off your issues as mine.
