Which RCA cables?
edited August 2013 in Speakers
I'm looking for a set of male to male RCA cables to hook my DAC up to my receiver. What do you guys use? All I can find are cheap looking ones on amazon. Also, is there a similar cable that I could hook to the same RCA cables with a 3.5mm jack on one end to play music through phones when people want to play something?
Post edited by kadrek on
Welcome!
    edited August 2013
    Are you going to ask this question in 3 different forums?
    edited August 2013
    For a $30 dollar DAC, the Amazon ones are fine. Good RCA cables can cost a few thousand each.
    edited August 2013
    Monster cables should have something available for you. Also audioquest or scosche. Crutchfield.com is a reliable place to find something like that.
    edited August 2013
    Monoprice.com
    afterburnt wrote: »
    Village Idiot of Club Polk
    edited August 2013
    Signal cable is a great bang for the buck interconnect, but I agree with a $30 dac it wont make much difference.
    edited August 2013
    B Run wrote: »
    +1
    However, if you get better cables now you can grow with them as you get better gear.
    edited August 2013
    For solid performing/relatively inexpensive cables I like BlueJeans Cable. Notably their digital coaxial using Belden 1694A.
    edited August 2013
    edited August 2013
    Acoustic Research interconnects are decent for the money and ebay has them for around $10 all day long.
    edited August 2013
    I'll send you some bulk cable and solder if you want to learn how to build your own.
    edited August 2013
    Attachment not found.I hook these to my iphone. They can be had at Radio Shack-WallyMART 10-15.00 or so..these are cheap Belkin and they work ok for a quick cheap hook up that sounds half way decent for phone (i use to audition receivers on the road). If your looking to use rca cables on a budget you can look online or local. A-1 on above suggestions. There are alot to be had on budget fairly reasonable. Good Luck W/search & welcome to CP
Welcome!
Welcome!
