Which RCA cables?
kadrek
kadrek Posts: 33
edited August 2013 in Speakers
I'm looking for a set of male to male RCA cables to hook my DAC up to my receiver. What do you guys use? All I can find are cheap looking ones on amazon. Also, is there a similar cable that I could hook to the same RCA cables with a 3.5mm jack on one end to play music through phones when people want to play something?
Post edited by kadrek on
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
    Are you going to ask this question in 3 different forums?
  • BlueFox
    edited August 2013
    For a $30 dollar DAC, the Amazon ones are fine. Good RCA cables can cost a few thousand each.
  • CSPolkKC
    CSPolkKC Posts: 1
    edited August 2013
    Monster cables should have something available for you. Also audioquest or scosche. Crutchfield.com is a reliable place to find something like that.
  • Nightfall
    Nightfall Posts: 10,084
    edited August 2013
    Monoprice.com
    afterburnt wrote: »
    Village Idiot of Club Polk
  • B Run
    B Run Posts: 1,888
    edited August 2013
    Signal cable is a great bang for the buck interconnect, but I agree with a $30 dac it wont make much difference.
  • Upstatemax
    Upstatemax Posts: 2,731
    edited August 2013
    B Run wrote: »
    +1
    However, if you get better cables now you can grow with them as you get better gear.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2013
    For solid performing/relatively inexpensive cables I like BlueJeans Cable. Notably their digital coaxial using Belden 1694A.
  • decal
    decal Posts: 3,205
    edited August 2013
  • Mystery
    Mystery Posts: 2,546
    edited August 2013
    Acoustic Research interconnects are decent for the money and ebay has them for around $10 all day long.
  • zingo
    zingo Posts: 11,258
    edited August 2013
    I'll send you some bulk cable and solder if you want to learn how to build your own.
  • boston1450
    boston1450 Posts: 7,758
    edited August 2013
    Attachment not found.I hook these to my iphone. They can be had at Radio Shack-WallyMART 10-15.00 or so..these are cheap Belkin and they work ok for a quick cheap hook up that sounds half way decent for phone (i use to audition receivers on the road). If your looking to use rca cables on a budget you can look online or local. A-1 on above suggestions. There are alot to be had on budget fairly reasonable. Good Luck W/search & welcome to CP
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
