Ordered New Amp Today/Fun Fun
  • bobsauto49
    bobsauto49 Posts: 973
    edited August 2013
    So far a tad harsher at the top at loud db, just a tad,and I mean at 98db and higher! I usually listen between 94-100db.orherwise fantastic!!!!!
    "Everything I ever did in my life worthwhile I caught hell for"
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited August 2013
    Im glad you are happy with your amps Bob,you been on a roll.Enjoy
    Dan
  • Monster Jam
    Monster Jam Posts: 919
    edited August 2013
    bobsauto49 wrote: »
    Not gonna happen! I only eat Cheetos,when I'm watching ****;-)
    Lick your fingers when your finished?
    Do you hear that buzzing noise? :confused:
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2013
    Bob have you noticed any thin mids with the panels ?
  • sponger
    sponger Posts: 325
    edited August 2013
    Of course a congratulations is in order. But, if no one minds my asking, can someone please explain to me in layman's terms exactly why other manufacturers aren't producing similarly powered amps that don't require he-man arms to lift? If I understand D-Sonic's website correctly, a 400x3 weighs less than 30 lbs. What is their secret? Thanks.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • polkfarmboy
    edited August 2013
    Alien crystals
  • trav0810
    trav0810 Posts: 1,056
    edited August 2013
    sponger wrote: »
    In Layman's terms...because it's much easier to reproduce old technology than to try to design something new! The money spent in developing a new technology or design is much higher than just altering the cosmetics of an amp and calling it a new model! lol And other companies have made lightweight "powerhouse amps. The 350WPC Carver M1.5t weighed under 20lbs.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
    tonyb Posts: 33,069
    edited August 2013
    sponger wrote: »
    Because weight isn't the main criteria. How it sounds is.
    Bob,
    At your listening levels, you sure your not hitting the Logan's limits for that harsh top end instead of thinking it's the amp ?
  • bobsauto49
    edited August 2013
    tonyb wrote: »
    Bob,
    Good point! However,I was using a db meter with the BAT,and the db were the same! And from everything I read,and heard,the montis's can go real loud,without much strain! Maybee they are!
    There is a lot of weight in the middle,and lower frequencies! So far,this may be a keeper! But I've got a lot more listening to do,before I make any rash decision!
  • pearsall001
    pearsall001 Posts: 5,258
    edited August 2013
    Ding! Ding! Ding! It sounds like we have a winner. The more you listen you'll pick up more of the amps muscle, it's subtle capabilities & just it's pure musicality. Keep on listening....it only gets better.
  • FTGV
    FTGV Posts: 3,650
    edited August 2013
    sponger wrote: »
    Put simply the Class D output stage with it's 90% ish efficiency negates the need for large heat sinking because unlike typical Class A/B designs most of the power is used to drive the speaker load,not pissing 50-60% of it away in the form heat.Powering it with a switched mode power supply (SMPS) means no beefy toroidal transformers or large filter caps are required.Adding it up results in considerable savings in both weight and space requirements.
  • drumminman
    drumminman Posts: 3,396
    edited August 2013
    bobsauto49 wrote: »
    What's the burn in time?
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2013
    Ding! Ding! Ding! It sounds like we have a winner...
    That's not what I read.
    I will say this: After listening to a piece of equipment for a long time, when I switch to a new piece I almost always listen with rose colored glasses initially, for a couple of reasons: 1, I want to justify my purchase, and 2, my ear is likely to take for granted what the old piece did well, meaning that I'm more likely to pay attention to what the new piece does better rather than what it does worse.
    In my experience it takes a long time to make a decision between similar quality pieces of gear.
    So pearsall, while I'm glad that you enjoy the d-sonic's "muscle, it's subtle capabilities & just its pure musicality", you would be mistaken to assume that the VK-500 does not possess those same qualities.
    This post is 100% objective and is in no way defensive of the BAT because I own one...:rolleyes::cheesygrin:
  • pearsall001
    edited August 2013
    BAT makes nice stuff.
