Dynamatted my drivers today, should I do the PRs too?
ipsullivan
I finally got around the Dynamatting the drivers on my RTA 11ts, turned out pretty good.
Should I do the passive radiators as well? I should have more than enough Dynamat left.
Also, I did not do the magnets. I read that some people suggest it, and others frown upon it. Any insight on why or why not?
Thanks,
Ian
Thanks,
Ian
Yes, do the PR's. The magnets do not ring, so no need to do them.
ipsullivan wrote: »Also, I did not do the magnets. I read that some people suggest it, and others frown upon it. Any insight on why or why not?
No need to Dynamat the magnets, as F1 said above. It is, however, a good idea to secure the magnets with some JB Weld, Loctite, or any other good ceramic/metal adhesive while you have the drivers out of the cabinets. This simple task should make the possibility of any of the magnets shifting - pretty much trashing* the driver - much less likely. There are several threads on this, with pics, available.
* - the driver can often be repaired after a magnet shift, but the process of doing so is, IMO, a delicate, tedious task that's not worth the time/effort required. -
We had this stuff at work called Plastic Dip and we would coat the handles of our tools with it.
What you are trying to accomplish here is to remove any ringing or reflection from the metal components in the speaker.
Has anyone tried another method? Polk had a cheap attempt to cut down on the ringing of the PR it was a thin cardboard ring
glued on the back, I only found this on my 2.3tls not my 1c and one of them had fallen off or was not put on properly to begin with.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Interesting. I know Dyna-mat is kinda of a tar based product and you would have a tough time cutting little pieces to get perfect coverage.
http://www.plastidip.com/home_solutions/Plasti_DipI had the same thing on the back of one of my 15TL's PRs.
Plasti-Dip in a heavy enough coat could probably have the same effect but you would have to avoid overspray onto the cones or spider.
Of course, you could probably brush on the non aerosol version...POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
With the passives having more open metal, I would think they would be more important to do then the drivers..
Plasti-dip has nothing on Dynamat, and I would never suggest using it on this application.. The time it would take to mask everything off is a deal breaker in its self, let alone you would never get the same thickness as Dynamat, nor the same quality..
I say bury that idea 6 feet under..
Looks like I will be doing the PRs tomorrow.
Also, one of the gaskets on one of the mids was a little bent and peeling a bit. Is there somewhere that I can get replacements for all the gaskets?
I agree, I have used Plasti-dip before(not for speakers) and it definitely does not come anywhere close to what Dynamat can do. -
ipsullivan wrote: »Looks like I will be doing the PRs tomorrow.
You can re-do all of your gaskets (MWs, PRs, tweeters and binding post cups) and have a ton left over with one roll of Armacell insulation tape. You can get a 30' x 2" roll from Home Depot for about $8. Just cut the tape into 1/2"-wide strips and stick them to the metal of the drivers, etc. Works like a charm, is cheap and easy to do. Just make sure you remove the old gaskets prior to sticking the new ones on. -
Yea it was just a thought and I was thinking about doing the PR since there is less chance of **** them up and they would probably need it the most.Most of the time, plasti-dip is only put on in one or two coats...and I agree, that won't come anywhere near to Dynamat.
But I am talking putting on enough coats to put it at or above the thickness of Dynamat.
Go to your toolbox and grab a pair of quality side cutters or linesman's pliers and look at the insulation on the handles. That's the thickness I am referring to. Plasti-dip builds up thickness rapidly with 5+ coats. I have experimented with coats up to 1/4 inch for other things.
But I digress as the time/materials would easily surpass the ease of Dynmat that can be had for about $25 for enough to do a pair of RTA-15TLs.
Just a thought for an alternative. I can send anyone who is interested a sample of some of the thicker applications for comparison if so interested.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Dynamat Extreme was designed as a dampening material. Plasti-dip was designed to coat things such as tool handles. Two very different products with two very different specific purposes.you would have a tough time cutting little pieces to get perfect coverage.
Dynamat Extreme cuts easily with scissors or a razor knife and perfect coverage is not needed for it to be 100% effective. All that is needed are strips on the spokes and in the case of a PR, apply some to the round end bell, that's it. -
I'm a little more anal retentive than that. I always do full coverage on the PRs and Drivers.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Complete overkill.
You remind me of me Andre, "Everything matters"!
Outstanding work/attention to detail!:cheesygrin:Testing
Testing
Testing -
Is Armacell relatively flexible once it is in a 1/2" strip? Will I be able to do each driver/PR with one strip?
Very easy to work with, compresses very easily. Before you cut one full length strip, save enough full width strips to do the tweeters also.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Complete overkill.
I agree. As nice of a job as that job is, one does not need that much to prevent ringing. Think about putting your finger on a ringing bell. Doesnt take much to silence it. -
Complete overkill.I agree. As nice of a job as that job is, one does not need that much to prevent ringing. Think about putting your finger on a ringing bell. Doesnt take much to silence it.Yep!!
Gee thanks guys. Regardless, it really helped the ringing which I was satisfied with. -
Yes, do the PR's.
Agreed. I found the PRs ring more because they don't have any deadening and mass provided by the magnet structure. -
Will Armacell work in this application?2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Just when I thought I was "done" messing with my theater, I come across this crap
...... Looks like its time to buy some Dynamat.
Do I really have to put it on the tweeter?? I have rt3000p's. rich
lolonkyo 5008, epson 8350, 148" DIY screen
4 svs cs ultras, 2 diy (fi) 18" sonosubs, sms-1 (2), ep2500 (2)
sunfire cinema grand signature
polk rt3000p x 6
polk cs1000p
panasonic BD
room treatments
monster power cond
converted 15x23x10 attached garage to dedicated theater
Read more: http://www.hometheatershack.com/forums/ported-subwoofer-build-projects/50656-where-can-i-buy-18-subwoofer-7.html#ixzz2X5Ff1nOj -
pietsch288 wrote: »Do I really have to put it on the tweeter??
There's no need to put it on any tweeter. -
I assume I should "mat" the 6"ers in the satalite speakers as well as the 8"ers in the sub? richonkyo 5008, epson 8350, 148" DIY screen
polk rt3000p x 6
polk cs1000p
panasonic BD
room treatments
monster power cond
Any woofer or passive radiator with a light weight, stamped steel basket frame will theoretically benefit from the Dynamatpietsch288 wrote: »I assume I should "mat" the 6"ers in the satalite speakers as well as the 8"ers in the sub? richHome Theater/2 Channel:
As long as I have the speakers out anyway......is there any other speaker or box mod must do's??onkyo 5008, epson 8350, 148" DIY screen
polk rt3000p x 6
polk cs1000p
panasonic BD
room treatments
monster power cond
Upgrading the components on your crossovers are a must do.
Is there a thread "for dummies" that I can follow/research. I love the rt3000p's and the cs1000p for what they are... but that doesn't mean they can't get better. I never imagined that the 3000's would be such a huge step forward over the other speakers I have had in the past. So if I can make them better I'm all for it. thanks richonkyo 5008, epson 8350, 148" DIY screen
polk rt3000p x 6
polk cs1000p
panasonic BD
room treatments
monster power cond
or maybe DHS speaker service??onkyo 5008, epson 8350, 148" DIY screen
polk rt3000p x 6
polk cs1000p
panasonic BD
room treatments
monster power cond
There are a lot of threads on crossover upgrades, but I don't recall seeing one for your speakers. Basically, it involves replacing the caps and resistors with ones of higher quality. The upgrades will make a vast improvement in the sound. If you're not up for doing them yourself, you might want to talk with member VR3.
What is DHS speaker service? -
That would be me F1nutThere are a lot of threads on crossover upgrades, but I don't recall seeing one for your speakers. Basically, it involves replacing the caps and resistors with ones of higher quality. The upgrades will make a vast improvement in the sound. If you're not up for doing them yourself, you might want to talk with member VR3.
What is DHS speaker service?Home Theater/2 Channel:
