Amp/Reciever to Power Monitor 70s?
124»
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2013
    tonyb wrote: »
    I assure you chief, I'm well aware of how it all works when it comes to power.
    Your taking some comments too seriously. While some of what you say may be true, it's more so common knowledge that doesn't bear repeating in every thread. We've covered power/watts/current....more times than fly's chasing Lady Gaga with her meat outfit on.
    That said, everyone's listening habits are different and so are the needs for power. Any speaker can benefit from more current and that applies to more than loudness. Will a lot of extra power go unused ? Yeah, possibly so....but that's an individual decision. Power is used for more than the amount of DB's you can push out your speakers. But then, most here know this and every comment about amps doesn't require a tutorial.
    Well said Tony.
    The biggest benefits of having a lot of power to drive your speakers is for greater clarity in instruments, vocals, and bass. It allows your speakers to operate to their full potential. I'd rather have it and not need it than need it and not have it.
    Now here is a quote I saved since it gave such a nice concise answer.
    So this is for you Yahoo. Now I'm going to put you on ignore, since you are simply here to cause trouble. I suggest the rest of you do the same. Without an audience he will crawl back into the uninformed hole he crawled out of.
    From your friends at about.com
    Quote:
    Q. Will My High-Powered Amp Blow My Speakers
    From Apply Now,
    Your Guide to Stereos.
    A. Many people wonder if an amplifier can blow their speakers when delivering full power to the speakers. The short answer is "No." The long answer is "well, if your amplifier is high-quality, you are OK." With power-handling, a higher rating is like almost everything else: more is always better. A speaker might have a minimum requirement for power handling, based on its sensitivity and performance, but will most likely have a maximum allowable amount.
    A speaker with a 100 watt power handling rating can be safely operated when connected to a 500 watt amplifier. The speaker is not going to explode or anything like that. The truth is that high amplifier power almost never destroys a speaker. In most cases, it is a lack of amplifier power that causes damage. The key is to use your speakers with an amplifier that produces sufficient output to drive the speakers to realistic sound volumes without distortion, or "clipping."
    Clipping occurs when the amp is asked to deliver more current to a speaker than the amp is really capable of doing. When an amplifier clips, it literally cuts off (or ... clips) the tops and bottoms of the musical waveforms that its trying to reproduce. This phenomenon introduces a huge amount of distortion into the output signal, and it is that distortion that kills speakers. The maximum power-handling amount stated on a speaker basically assumes that the amplifier is going to "clip" or start to produce distortion at its maximum output. So, if you use a low-quality amplifier, it will start to run out of gas at its max output, and might do damage to your speakers.
    A high-quality amp usually produces ample power without clipping and thus it avoids the introduction of speaker-killing distortion.
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2013
    I put him on ignore two pages ago lol.
    Main Surround -
  • GFOviedo
    GFOviedo Posts: 353
    edited August 2013
    the 70s love the juice.
    That just doesn't sound right!
    AVR: DENON X4000
    FRONT L/R: ARX A3RX-C
    CENTER: ARX A2RX-C
    SURROUND L/R: ARX A3
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
    MEDIA PLAYERS: DUNE SMART SERIES D1
    HDTV: VIZIO M601D-A3R
  • ibewbrother
    ibewbrother Posts: 186
    edited August 2013
    How about....I can peak the meters on that 45 and the 70s just rock on... sure ..it is hearing damage level....but the speakers just do their thing...
    "Making life enjoyable through expensive electronics." BillD
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
    Carver TFM-45 (mains)
    Carver A753x (center, surround)
    320GB PS3, 42" Panasonic G10,
    M60's as a Zone 2 off of the Pioneer in the living room
    R.I.P. Onkyo TX-NR807
